Alexey Vanzhula Posted April 11, 2020 Share Posted April 11, 2020 Product link: https://gum.co/KYCgR What's new: 1. The Modeler core has been completely rewritten. Performance, stability and UX are improved. 2. A hotkey system has been created. Hotkeys are now configured in a separate editor (Hotkeys shelf tool). The editor allows you to quickly configure keyboard and mouse shortcuts. Unlike other modeling programs, you can now associate any tool with any combination of keys or mouse actions. In a similar way, the mouse and keyboard are configured in Nevercenter Silo, but unlike Silo, there are no restrictions here. That is, you can assign absolutely any tool to the mouse. On the other hand, mouse tools such as interactive selection can also be assigned to keyboard shortcuts. Also, unlike the standard Houdini behavior in Modeler, you can use the additional two mouse keys X1 and X2 (Ctrl+X1, Shift+Ctrl+X2 etc). The Hotkeys editor has two default mouse layouts: 1. Standard - that works just like DM and the previous Modeler version - LMB to select items and MMB to drag them 2. Pro - which allows us to select geometry components with RMB and drag with LMB. MMB used to select invisible items too. 3. The interactive state system (add-on for Python States) has been rewritten from scratch. Many tools have become more interactive and have the ability to customize the node in the viewport. In addition, you can quickly create custom interactive python tools for your own HDAs. The mouse wheel now works more universally. In many nodes, the wheel allows you to change the Uniform Scale parameter. List of nodes that now use state tools: Soft Boolean, Insert Mesh, QPrimitive, Array, Hose, Bevel, Extrude, Bridge, Set Flow, Smooth Points, Thickness, View Deform. 4. Retopology tools (Topo category) have been redesigned. TopoDraw tool (Alt+A) allows you to quickly draw poly patches on the reference geometry. It has an ability to snap to existing geometry. Topo mode (Alt+T) now packs the reference model. This speeds up the entire process of retopology with millions of faces. The Push tool now works in the Topo mode, which allows you to get the desired result even faster. In addition, the Push tool has improved performance and stability. 5. The Insert Mesh SOP was redone from scratch. It has interactive tuning, better performance, and more accurate results thanks to improved normals. 6. The Deform menu was merged with the Align menu and renamed to Transform Menu (Z). 7. The Relax tool renamed to Smooth. The tool is completely redesigned and takes advantage of Python States. Using the Smooth tool, you can smooth points or polygons in a standard way. On the other hand, the edges are smoothed as separate curves. Combined with interactive enhancements, the tool allows you to quickly fix messy areas. 8. Tools that create modeling nodes were removed from the Modeler shelf. Only general tools are now on the shelf. Direct modeling tools are now called from the Modeler mode. Added shelf tools: Delete Node, Merge Nodes, Stash History, Pack History, Clean History и Delete Attribs 9. Added a new tool Repeat Node Parms that allows you to apply settings from previously created nodes of the current tree 10. ToolsPanel (spacebar) renamed to Launcher. Launcher tools have been re-sorted and have a new Mouse section for interactive tools like selection or dragging 11. For Bevel, Bridge, Extrude and Smooth tools separate nodes were created 12. Bevel, Extrude, Inset, Smooth, Thickness hotkeys can work as sticky keys. That is, the call of a hotkey, for example, of the Extrude tool, leads to an instant change of the extrusion value before releasing the key. 13. Added Inset tool that uses Extrude SOP. In contrast to the Extrude tool, the first time you start Inset, you can change the inset with LMB. 14. The Lattice tool removed. It is now replaced by improved View 4 and View 9 (View Deform) from the Transform menu (Z) 15. Tools for a quick preview of the subdivided geometry were created: Preview Subdivide (Alt+1) и Preview Subdivide Wire (Alt+2). Standard viewport subdivision and instance subdivision (Symmetrize Tool) ar assigned to Alt+3 и Alt+4 respectivelly. 16. Select By Normals mode (6) allows you to select components based on normals 17. Local transformation tools have been added to the Transform menu: Local Move, Local Rotate и Local Scale 18. An Extend (Y) tool. This add-on to the Extrude tool allows you to quickly extrude edges and polygons using handles. 19. The Bridge Connected tool returned from the DM package 20. Slice, Clip and Mirror tools have the ability to set the initial origin based on points selection center 21. On the next call, the Delete tool changes the node so that it deletes unselected geometry. 22. The KitBash tool now offers to automatically create a KitBash panel if it is not created 23. Shift+Double Click can now replace the geometry of the current Insert Mesh SOP with the geometry from the KitBash panel 24. Combine and Boolean now offer to select nodes at the object level if the tool was launched inside the SOP container 25. Set Flow creates more accurate geometry in unusual situations. 26. Added a Point Weld tool (Alt+W) for interactive point stitching 27. The Soft Boolean SOP can be configured interactively. It also has a slightly improved performance. 28. Collapse History (Left) renamed to Pack History 29. Many tools are assigned to new hotkeys. The ToggleCompass tool is now called with the Backspace key. 30. The Edit Mesh shelf tool now renamed to Modeler 31. Modeler now moved to the package Houdini system instead of using houdini.env Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted April 12, 2020 Share Posted April 12, 2020 Hi Alexey, Is this a free upgrade for those that purchased Modeler 1.0 from you last month? Wasn't expecting a newer product, when the previous version was a 1.0 release. Will there be supporting videos for these new H18 versions of Modeler? Has the zone and quick launch menus been re-implemented? It's listed on pages 20-21 of the Modeler 1.0 manual, but there is no menu icon or routine to setup the hotkey for, as per the instructions. Is there a direct way to contact you regarding updates and issues with the product? Cheers. 2 Quote Link to comment Share on other sites More sharing options...
bobc4d Posted April 12, 2020 Share Posted April 12, 2020 will there be tutorials for this new version or at least product demo? 1 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted April 26, 2020 Author Share Posted April 26, 2020 Modeler 2020.1 for Houdini released! https://vimeo.com/412027905 2 Quote Link to comment Share on other sites More sharing options...
andrevallecg Posted May 5, 2020 Share Posted May 5, 2020 Hi Alexey, My name is André Valle, I'm a Houdini user, and I want to know if there's a discount to buy now your great plugin? It's a really amazing tool. I read that you gave a discount in February, am I right? Thank you. Best regards! André valle Quote Link to comment Share on other sites More sharing options...
sidbore Posted May 30, 2020 Share Posted May 30, 2020 (edited) Plugin worked only after I copied it to C:\Users\username\Documents\houdini18.0 Insert Mesh to work if click alt + 2 clicks of the left mouse button on the picture I took this free kitbash https://gumroad.com/d/82ff256324d8d4816154051c3f02ce8b And adapted for correct work in the plugin. Maybe someone will come in handy. https://mega.nz/file/dU5RGBDL#sVxH1XBcFwdIVEH8A2mcMzHJypLqbliGxMkQZLZy3Qk Sorry for english (google translate) Edited May 30, 2020 by sidbore 1 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted May 31, 2020 Author Share Posted May 31, 2020 On 5/30/2020 at 12:13 AM, sidbore said: Plugin worked only after I copied it to C:\Users\username\Documents\houdini18.0 Insert Mesh to work if click alt + 2 clicks of the left mouse button on the picture I took this free kitbash https://gumroad.com/d/82ff256324d8d4816154051c3f02ce8b And adapted for correct work in the plugin. Maybe someone will come in handy. https://mega.nz/file/dU5RGBDL#sVxH1XBcFwdIVEH8A2mcMzHJypLqbliGxMkQZLZy3Qk Sorry for english (google translate) Expand Great job! You can give me all the models, I will adopt it for insert mesh in the next major update. Also, I want to add an ability to use closed meshes as Insert Mesh source Quote Link to comment Share on other sites More sharing options...
Neil78 Posted June 1, 2020 Share Posted June 1, 2020 Hi Alex Thanks for the modeler tool-set - its fantastic latest build .12 giving me errors - version .11 works fine When i hit a radial menu I can launch it successfully. However if I hit a radial menu again from scratch it doesn't respond, (unless I rotate the scene view slightly..) Means quick radial use becomes impossible - for example F1 suddenly loads help browser...... Getting these messages - ( although i get these in .11 also and don't have the problems ) Qt Warn: Case insensitive sorting unsupported in the posix collation implementation Qt Warn: Numeric mode unsupported in the posix collation implementation Thanks Neil Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2020 Author Share Posted June 1, 2020 On 6/1/2020 at 3:30 PM, Neil78 said: Hi Alex Thanks for the modeler tool-set - its fantastic latest build .12 giving me errors - version .11 works fine When i hit a radial menu I can launch it successfully. However if I hit a radial menu again from scratch it doesn't respond, (unless I rotate the scene view slightly..) Means quick radial use becomes impossible - for example F1 suddenly loads help browser...... Getting these messages - ( although i get these in .11 also and don't have the problems ) Qt Warn: Case insensitive sorting unsupported in the posix collation implementation Qt Warn: Numeric mode unsupported in the posix collation implementation Thanks Neil Expand Thank you! What Houdini version and OS? Quote Link to comment Share on other sites More sharing options...
bobc4d Posted June 1, 2020 Share Posted June 1, 2020 hello, I too am having this issue now. I have latest daily build for win 10, 18.0.484. the radial menu does not show nor does pressing spacebar bring up menu Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2020 Author Share Posted June 1, 2020 (edited) Ok. Thanks, guys. I will fix it in a few days Edited June 1, 2020 by Alexey Vanzhula 2 Quote Link to comment Share on other sites More sharing options...
sidbore Posted June 1, 2020 Share Posted June 1, 2020 On 5/31/2020 at 1:05 PM, Alexey Vanzhula said: Great job! You can give me all the models, I will adopt it for insert mesh in the next major update. Also, I want to add an ability to use closed meshes as Insert Mesh source Expand Of course, take it, I will be glad. https://mega.nz/file/dU5RGBDL#sVxH1XBcFwdIVEH8A2mcMzHJypLqbliGxMkQZLZy3Qk Using closed meshes - is great news. It would be nice if the node "normal" was automatically connected. 1 Quote Link to comment Share on other sites More sharing options...
Neil78 Posted June 1, 2020 Share Posted June 1, 2020 On 6/1/2020 at 5:15 PM, Alexey Vanzhula said: Ok. Thanks, guys. I will fix it in a few days Expand Thanks Alexey im using 18.0.460 on centos 7.8 Thank you Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2020 Author Share Posted June 1, 2020 0 Advanced issue found ▲ 2 On 6/1/2020 at 10:07 PM, Neil78 said: Thanks Alexey im using 18.0.460 on centos 7.8 Thank you Expand Can you record a short video? If so, please open Python Shell before Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted June 2, 2020 Share Posted June 2, 2020 Hi Alexey, Will Modeler 2020 be a a free upgrade for those that purchased Modeler 1.0 from you last month? Wasn't expecting a newer product, when the previous version was a 1.0 release. That's a very expensive one-off purchase... Will there be supporting videos for these new H18 versions of Modeler? Has the zone and quick launch menus been re-implemented? It's listed on pages 20-21 of the Modeler 1.0 manual, but there is no menu icon or routine to setup the hotkey for, as per the instructions. Is there a direct way to contact you regarding updates and issues with the product? Cheers. P.S. Re-posting from above, in case you didn't see this. Quote Link to comment Share on other sites More sharing options...
Neil78 Posted June 2, 2020 Share Posted June 2, 2020 On 6/1/2020 at 10:10 PM, Alexey Vanzhula said: Can you record a short video? If so, please open Python Shell before Expand Sure - I’ll do that first thing in morning and send 1 Quote Link to comment Share on other sites More sharing options...
Neil78 Posted June 3, 2020 Share Posted June 3, 2020 (edited) Hey Alexey - sorry false alarm! I got it working again.... for some reason unplugging my wacom from a USB 2.0 port and then plugging into a USB 3.2 gen 2 Type A port .... saved the day All works fine - no issues Sorry to be a bother - thanks again for the modeler tools - I think they are great N Edited June 3, 2020 by Neil78 spelling 1 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted September 11, 2020 Author Share Posted September 11, 2020 (edited) Hi guys! I need money, so maybe it is the best time to save your money. Modeler for Houdini 50% OFF https://gum.co/KYCgR/i7trzdz Edited September 11, 2020 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted September 22, 2020 Author Share Posted September 22, 2020 Quote Link to comment Share on other sites More sharing options...
Colemapt Posted October 23, 2020 Share Posted October 23, 2020 Hey does this work in 18.5? Just purchased it and am trying to get it running but its not showing up anywhere Quote Link to comment Share on other sites More sharing options...
