setting up Flip distributed Simulation on a single machine
crow9350
How can I set up Flip distributed Simulation on a Single machine?
and do I need Houdini HQ?
Houdini Master Class demonstrates distribution sim on multiple machines, so I have no idea how to set it up in a single machine.
I know it requires more memory, but what I'm trying to do is too big so it seems impossible to do it with just regular setting.
I anticipate 1gb of file size of fluid or white water per frame if I do it with regular setting,
I think it would take up to 2 to 3weeks on my computer. and I'm not sure my computer can handle it.
(my cpu is amd ryzen2700, ram64gb, windows10)
Do you think it is still better without distribution?
  • 1 year later...
On 25/06/2020 at 7:07 PM, tamagochy said:
I think you need to do more simple project or find the way to simplify current. Distribution on one machine have no profits.
What if you need to do a flip sim that requires 10 km and 100 million particles but can only sim 20 million before your machine crashes?  Can you use distributed with/without HQueue to slice it up and just sim 5x on the one machine, but in the end have a nice 100 mill sim?
Edited by HM_2020
12 hours ago, dleonhardt said:
Distribution on a single machine is only really useful for faster sim times. There are a couple of parts of the FLIP solver which are still single threaded.
This. It can be faster if the synchronization between the slices doesn't take longer than the single threaded parts would take on their own. Doing this doesn't turn 64GB of RAM into 512GB of RAM. All of the slices still need to be running concurrently so they can be synchronized after each timestep. If anything it would use even more RAM running a distributed simulation on one machine compared to a single simulation. Here's some cool reading if this stuff is interesting to you.
https://en.wikipedia.org/wiki/Amdahl's_law
  • 2 weeks later...
Well that sucks.  So you can not simply sim one slice, finish, sim another etc on one box?  Damn...
No simple way unfortunately. You could do it similarly to PhoenixFD's Cascade Simulation feature, but transferring sim data from one domain to another and have it be relatively seamless, is not trivial to do to say the least.
  • Sad 1
1 hour ago, tamagochy said:
What worth to try its make few sims with lower res and combine them, and then mesh result
Yeah I thought of that, just do a bunch of small domains with edge boundaries, combine all the flip sims into one with soft edges, then do whitewater from that...  but it will look like mixed sims a bit.
  • 3 years later...
We can do this with Deadline by submitting a Distribute Simulation FLIP job to the render farm. If there's only a single machine in the farm, it will automatically complete one task of the job and then continue to the next. As far as I know, Distribute Simulation only works with a DOP setup.
I was mistaken, the entire simulation must run in parallel. If even one machine crashes during operation, the whole job fails.
Edited by paranoidx
correct practical
