Tutorial HIP Library
Atom
14 hours ago, Librarian said:
@crispr_boi Check this :P.. and Please post some tutorials that you on Your Spare Time.don't care I just want hip...:wub:..and (you have Internet exactly like me) use wisely  -Made/from any Source.
ok :ph34r:...mmmm ..Lovely Idea.. (i post my source , just be More Active) if you have time ..mmm ..and on my language(polabrnjaj)
from Zambia .
Thank you for what you're doing for the community! Your hips and help on odforce is priceless!
  • 2 months later...
I worked my way through the vellum hairball stretch tutorial.
ap_vellum_hair_tear_tutorial_071423.hiplc
Here's a variation where lines are generated inside each letter of a remeshed font using the findshortestpath node. This let's you pull apart a word.
ap_kr_vellum_hair_tear_tutorial_071423.hiplc
Edited by Atom
  • Like 5
  • 4 weeks later...
  • 4 weeks later...
Building on chapter 14 of the particle planet tutorial series posted on SideFX, I extended the scene to detect when the particles escape the surface. After they age two seconds, a popseek draws them back to the surface.
White lines never leave the surface, lavender are free roaming, and yellow are free roaming aged particles heading back to the surface.
There are lots of noise control to vary the speed and timing.
ap_tut_particles_around_sphere_090323.hiplc
Edited by Atom
  • Like 5
  • 1 month later...
  • 2 weeks later...
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
I worked through the room map setup inside the Houdini 20 help. Here's an example file setup to  produce a Karma render using the default room map. I'm attaching the roommap_debug.exr file so you'll have an example of how to create your own room maps. Just remember to preserve the alpha channel on boxes marked S1-S4. It would be nice if SideFX would post a few starter room maps to the Content Library.
It looks like there are a few free maps here: (scroll down to free scene)
https://wparallax.com/
roommap_debug.exr ap_sidefx_room_map_styles_041424.hiplc
Edited by Atom
  • Like 2
  • 3 weeks later...
  • 2 weeks later...
I have reworked Alejandro's fill a flip collider from an exterior source. This re-work of the network uses the newer H20 nodes.
NOTE: If you get a font error, just pick one that is on your system.
Original HIP files found here:
ap_pazuzu_FLIP_fill_FONT_from_outside_050824.hiplc
Edited by Atom
  • Like 5
  • 1 month later...
