Sinsterz Posted April 18, 2022 Share Posted April 18, 2022 (edited) I created an infection solver to imitate the infection of fire spreading that is functional with a popnet as the source of the infection. I did it this way because the pyro spread node does not support pops as a source which is a different problem entirely. Everything works as it should however the infection solver only takes into effect after frame 9 which is strange because the pops should clearly be infecting from the very beginning. For some reason the solver doesn't take into account the beginning frames. Ive used this solver in other projects and has worked fine which leads me to believe it is a bug but if anyone could look over my project file and let me know if they see anything I don't? Thanks so much the file is setup so that you should press play and the problem be evident, the pops are red, wherever the infection is, is white and everything else i.e. the desk and papers should be black. After frame 9-10 the infection will begin although it should begin where ever the pops collide. InfectionSolver.hiplc with geos InfectionSolver.hiplc Edited April 18, 2022 by Sinsterz Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 18, 2022 Share Posted April 18, 2022 @Sinsterz Please freeze Geometry (include) Quote Link to comment Share on other sites More sharing options...
Sinsterz Posted April 18, 2022 Author Share Posted April 18, 2022 @Librarian my bad this is my first time posting a houdini file, i believe everything should be in there now except for all the file caches. But all the custom meshes should be locked in thanks again for taking a look Quote Link to comment Share on other sites More sharing options...
Atom Posted April 18, 2022 Share Posted April 18, 2022 It seems to work. Try increasing the Threshold on the wrangle inside the solver. Quote Link to comment Share on other sites More sharing options...
Sinsterz Posted April 18, 2022 Author Share Posted April 18, 2022 @Atom how strange. I did try that but nothing changed within those first few frames, i may just need to recreate the project in a different file Quote Link to comment Share on other sites More sharing options...
Sinsterz Posted April 18, 2022 Author Share Posted April 18, 2022 So I figured it out, the nearpoint function i was using needed some tweaking, thanks to everyone who looked at my file. Quote Link to comment Share on other sites More sharing options...
