Stalkerx777
Houdini UI Python Library
Hi, guys!
Just wanted to share with you some of my experiments.
huilib - is a simple Python wrapper around Houdini's native .ui language. It has been written "just for fun", so no warranty if it works for you, but I think it's pretty usable for a simple UI, in situations, when using PyQt is not an option  :P
Maybe someday we'll see something similar from SESI  :)
Feel free to use it.
https://bitbucket.org/alexxbb/huilib/overview
post-3906-0-34336100-1392326946_thumb.jp
Edited by Stalkerx777
  • Like 6
Share this post
Link to post
Can we do something similar with pop up windows ? ei mixing drop down menu with text box and a 3 buttons selection?
Maybe this lib can do that ?
Sorry I'm still new to this programming world and I'm trying to create some basic tool, like loading cam(alembic) and create new scene with naming convention, etc ...
thanks
Share this post
Link to post
thanks
Yes, it actually what this library supposed to do. Simple pop up dialogs for simple things =)
Share this post
Link to post
Very nice! Cheers! ;) (Also, the function you use, hou.ui.createDialog() doesn't seem to be documented anywhere in the 13.0 docs, so your code is extra useful...)
Share this post
Link to post
Very cool! Is there a way to use this library without launching Houdini? (I'm guessing not, but just in case...)
Thanks!
Share this post
Link to post
Thanks!
No, unfortunately not :)
Share this post
Link to post
thanks for the huilib nice tool.
i found a little error in the HVector, i think i fixed it though by changing
from
assert 2 < size <= 4, "HVectorField size can be 2, 3 or 4"
to
assert 1 < size <= 4, "HVectorField size can be 2, 3 or 4"
from the huilib.py
i also found out that when i launch the interface and just run my code right away
the setValue() outputs blank, instead of 0 which is what the interface seem to show.
it fixes itself though if you drag the slider out and back to 0. then it outputs 0
i also have a problem with setValue() with HVector in 2d. it works if the size =3 but if its 2 and i tried self.someNameofVector.setValue([0,1]). or ((0,1)), it errors something like index out of range. with something about _multivalue thingy.
Edited by willow wafflebeard
Share this post
Link to post
very useful tools! thaks!
i have a  question about the(self.stringField = huilib.HStringField('field1', 'meName')):
import huilib
from huilib import *
class meDialogxx(HDialog):
    def __init__(self, name, title):
        super(meDialogxx, self).__init__(name, title)
        self.setWindowLayout('vertical')
        self.setWindowAttributes(stretch = True, margin = 0.13, spacing = 0.1, min_width = 3)
        colx1 = HColumnLayout()
        self.stringField.setEnabled(True)
        #self.geoFileField.getValue()
        #print self.stringField
        self.addGadget(self.stringField)
        rowx1 = HRowLayout()
        self.a000 = HButton('aa','COM_0')
        self.a001 = HButton('bb','COM_1')
        rowx1.addGadget(self.a000)
        rowx1.addGadget(self.a001)
        colx1.addLayout(rowx1)
        self.a000.connect(self.cb_printStringFields)
        self.a001.connect(self.cb_printStringFields1)
        self.addLayout(colx1)
        # This method should always be called last!!
        self.initUI()
    def cb_printStringFields(self):
        a=self.stringField.setValue('aaaaaa')
        self.stringField.getValue()
    def cb_printStringFields1(self):
        self.stringField.setValue('a+b')
if __name__ != '__main__':
        ui = meDialogxx(name = 'import_dlg', title = 'what the F$%%^%&*^*')
        ui.show()
how can i get the (self.stringField) value?please!!!
Share this post
Link to post
So what's a problem? It works, just checked.
self.stringField.setValue("MyValue") # Set value
print self.stringField.getValue() # Pring Value
Share this post
Link to post
Thanks for this wonderful tool. I got 2 questions:
1. How to implement a proper HIconButton with built in icon?
2. Is there any way to query an opened window and close it first before committing a new one?
Thanks
Share this post
Link to post
Thanks
2
1. I've tried many times, but couldn't make it work. Need to ask SESI support how to use ACTION_ICONBUTTON gadget.
2. Yes:
# Find the dialog by name
ui = huilib.findDialog('test')
if ui:
	# If found you can show(), hide(), and close() it
	ui.close() will close and delete the dialog
ui = TestDialog(name='test', title='Test UI')
ui.show()
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
