Juraj Posted October 3, 2014 Share Posted October 3, 2014 Hello, I'm playing with bullet dynamics in Houdini. But I'm having quite often one problem - strange motion in e.g. small shards on ground plane. They don't stop moving even after few seconds after they fell on the floor. They are not changing position but just slightly rotating. This motion seems to go on and on... According to docs Linear/Angular Treshold parameter in RBD Packed Object should fix it, but it doesn't seem to have any effect. Have you experienced this type of error and if - have you solved it? Thanks Quote Link to comment Share on other sites More sharing options...
pgrochola Posted October 6, 2014 Share Posted October 6, 2014 try lowering your collision padding. If you switch on display collision geo in dops I bet the small pieces look very rounded (because collision padding is too low) Will change the look of your sim though best to avoid siming really small pieces. 2 Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 6, 2014 Author Share Posted October 6, 2014 Thank you for your help, I'll tweak those parameters until it's ok. Quote Link to comment Share on other sites More sharing options...
henrik.g Posted October 7, 2014 Share Posted October 7, 2014 Hey everyone, I have the problem too... And if everyone says you should work in scale, then this happens like really often... So what I did was: Scale everything up by a factor of 10 and then after the Sim scale it down by the same factor. Would that change the accuracy? Is there any "good" work around to this? Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 10, 2014 Author Share Posted October 10, 2014 try lowering your collision padding. If you switch on display collision geo in dops I bet the small pieces look very rounded (because collision padding is too low) Will change the look of your sim though best to avoid siming really small pieces. Hi. I've tried lowering collision padding. It improved simulation a little bit but when I set it really low, glued objects became unstable and started "vibrating". Is there a better solution? I'm trying to simulate wood shattering so I need small pieces. Is there any way how to do it in bullet or houdini rbd solver is the only way? Hey everyone, I have the problem too... And if everyone says you should work in scale, then this happens like really often... So what I did was: Scale everything up by a factor of 10 and then after the Sim scale it down by the same factor. Would that change the accuracy? Is there any "good" work around to this? Hi I tried your solution, but it really affected the look of my simulation. Everything was slower and I had to tweak all constraints parameters to get similar look. I hope there is another solution. Anybody can help me? It seems like basic thing to do in Houdini but I cannot figure it out. Quote Link to comment Share on other sites More sharing options...
alksndr Posted October 11, 2014 Share Posted October 11, 2014 Have you tried turning the sim off when you've reached a good stopping point? Either via keyframe active or just cache it up to a certain frame. I'd also play around with the substeps in the rbd solver, but its not really higher number = better, you just gotta try random numbers. For example if you just drop a default voronoi fracture sphere with 10 substeps it will have these pieces in the middle that just stand and spin forever, putting it on 25 will make them drop and stop almost perfectly, combining that with turning off the sim = works great. But 30 substeps make it behave almost like default. So try and play around with those 2 things? Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 11, 2014 Author Share Posted October 11, 2014 Have you tried turning the sim off when you've reached a good stopping point? Either via keyframe active or just cache it up to a certain frame. I'd also play around with the substeps in the rbd solver, but its not really higher number = better, you just gotta try random numbers. For example if you just drop a default voronoi fracture sphere with 10 substeps it will have these pieces in the middle that just stand and spin forever, putting it on 25 will make them drop and stop almost perfectly, combining that with turning off the sim = works great. But 30 substeps make it behave almost like default. So try and play around with those 2 things? Yes, I finally found good combination of substeps and collision padding parameters and deactivating them when needed. I'm wondering if there is a way to per-piece deactivation when certain velocity treshold is reached. For example having sop solver, which will compare object's velocity and if it is smaller than treshold, it will turn it off. Quote Link to comment Share on other sites More sharing options...
Cain&Able Posted October 12, 2014 Share Posted October 12, 2014 Well you have the rbd auto freeze in dops that will do that. I found to an extent bullet works, but being based on a fast and dirty games solver it's not great for everything. Try to the auto freeze though. Quote Link to comment Share on other sites More sharing options...
Juraj Posted October 12, 2014 Author Share Posted October 12, 2014 Well you have the rbd auto freeze in dops that will do that. I found to an extent bullet works, but being based on a fast and dirty games solver it's not great for everything. Try to the auto freeze though. Yes, RBD is probably more accurate. And RBD Auto Freeze works only with rbd objects. But I chose to play with bullet because you can dynamically create complex constraint networks and use benefit of packed primitives. But it probably needs more tweaking to get satisfactory results. Quote Link to comment Share on other sites More sharing options...
Popular Post Juraj Posted October 12, 2014 Author Popular Post Share Posted October 12, 2014 (edited) I found here on forums quite good solution: * lower collision padding in rbd object * pop drag node (works with packed prims) with vex code: if (length(@v)<0.4) { airresist = 30; } * pop wrangle: if (length(@v) < 0.4) { v@w *= 0.85; // rotational velocity drag v@v *= 0.85; // velocity drag}if (length(@v) < 0.05 && @Frame > 50) { i@active = 0;} Edited October 12, 2014 by Juraj Tomori 14 2 Quote Link to comment Share on other sites More sharing options...
radurock Posted February 21, 2015 Share Posted February 21, 2015 (edited) thanks for this Juraj! one question...is the wrangle cooked every substep? edit : yep it's per substep Edited February 22, 2015 by radurock Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted November 20, 2016 Share Posted November 20, 2016 this thread is gold thankyou thankyou thankyou Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted January 3, 2018 Share Posted January 3, 2018 I have two recommendations. First, make sure that you have no extra forces in your sim creating a perpetual motion for the shards. Disable all other forces other than gravity. Does the sim come to a stop now? If it does, you are probably adding forces in an incorrect way, creating that perpetual motion. Second, I increased the Angular and Linear Threshold parameters. This increases the speed at which the shards are considered not-moving. This worked best for me. Quote Link to comment Share on other sites More sharing options...
tony Posted January 4, 2018 Share Posted January 4, 2018 On 07/10/2014 at 9:02 AM, henrik.g said: Hey everyone, I have the problem too... And if everyone says you should work in scale, then this happens like really often... So what I did was: Scale everything up by a factor of 10 and then after the Sim scale it down by the same factor. Would that change the accuracy? Is there any "good" work around to this? I generally find the scaling by 10 solution works well for me - not had any noticeable accuracy issues with it. Is a bit annoying having to adjust all forces and colliding objects etc though. I usually combine this method with some wrangles which drag and deactivate the pieces once they get too slow (similar to what Juraj detailed above). Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted January 4, 2018 Share Posted January 4, 2018 I think they're good. This thread is from 2014... 2 Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted July 25, 2018 Share Posted July 25, 2018 I got to this page, but the problem was actually a lot simpler than I had imagined. Check what objects you are using as RBDs!! I was using a bunch of little spheres, so obviously these would keep rolling easily. Changing my rbd objects to little boxes largely fixed the issue, but im sure any faceted object would have worked. Quote Link to comment Share on other sites More sharing options...
bmn123bmn Posted July 27, 2018 Share Posted July 27, 2018 I think you guys need "pop speed limit" and "pop spin limit" node. Quote Link to comment Share on other sites More sharing options...
sasasa741 Posted December 2, 2018 Share Posted December 2, 2018 I have the same problem. Can anyone help me ? my hip file https://drive.google.com/file/d/1JfxsLBNlSW0b7rktH_mPswa2CdBZs807/view?fbclid=IwAR3OlgrmmcqhHwPKeLkCxm18CsNuqODAjWV2MjxjzCCaErFRMgtXJMStg1s Quote Link to comment Share on other sites More sharing options...
Musi Posted December 14, 2018 Share Posted December 14, 2018 On 2018. 12. 3. at 4:55 AM, sasasa741 said: I have the same problem. Can anyone help me ? my hip file https://drive.google.com/file/d/1JfxsLBNlSW0b7rktH_mPswa2CdBZs807/view?fbclid=IwAR3OlgrmmcqhHwPKeLkCxm18CsNuqODAjWV2MjxjzCCaErFRMgtXJMStg1s Hey Bro, I think you don't like the box keeps rotating. I suggest a simple way which is decreasing "Sleeping Time" in bullet. Quote Link to comment Share on other sites More sharing options...
bmn123bmn Posted December 21, 2018 Share Posted December 21, 2018 ok, I have this problem for a really long time! not only the moving issue and also the crazy rolling issue. what you guys need is a "pop speed limit" node ! cheers Quote Link to comment Share on other sites More sharing options...
