How to enter my code presets in a Wrangle ?
sebkaine
Hi Guys,
There is now this great menu at the right of the text field where you can use code presets inside a wrangle.
I would like to know where i can customise this code and enter my own presets.
Thanks for your lights !
Cheers
E
Under installed Houdini there is the File: VEXpressions.txt
Copy to your User Path and edit it.
Have Fun. :-)
EDIT:
No Fun i didn't get it to run with a seperated File VEXpressions.txt. I also have seen that Houdini has a Python code That loads the list but it doesn't load my values. *arrrggghh*
i do something wrong but i don't know what.....
Python Code under: vexpressionmenu.py
you can run it in Python Shell:
# Python Code
import vexpressionmenu as v
v.loadSnippets()
Edited by Mandrake0
I could have sworn I saw it in the docs, but the only references google returns are from the sidefx forum and odforce. Anyway.
Create a file called vexpressions.txt in your ~/houdini folder, put your snippets in there. There's a slightly odd formatting to use, not too bad. Eg, I just tested this:
attribwrangle/snippet
    delete x% of points with slider
	    if (rand(@ptnum)< ch('threshold')) {
			removepoint(0,@ptnum);
The indentation determines what the category/comment/code is, its documented within the example vexpressions.txt file which you can find by running this in the houdini python shell:
hou.findFiles('vexpressions.txt')
'vexpressions.txt' file name doesn't work for me but VEXpressions.tx is ok !!
Thanks
Thanks
it need to be VEXpressions.txt otherwise the hou.findFiles won't find it.
Python Code (vexpressionmenu.py):
def loadSnippets():
    """ Loads all the vexpressions from the VEXpression.txt
        files found in the houdini path.
    try:
        filelist = hou.findFiles('VEXpressions.txt')
  • 2 months later...
Hi
You actually don't have to do that funky indentation to make this work, but you have to omit special characters like %:
If you write it like this it'll work and you'll get the indentation you put into the snippet:
    Delete x of points with slider
-b
PS i wish the Code -> No formatting could be changed from black text on dark gray background. Doesn't have to be fancy. Just readable :)
