My R'n'D
tamagochy
Hi guys, I'm now switching from max to houdini and makes some r'n'd i want to show to you.
House destruction. It need a lot of improvements but it takes long time maybe i will add it later. One thing I cant solve it is a pixelisation of the smoke in dissipate areas. It happens when i use noise in pyro shader and only in this simulation.
Edited by tamagochy
  • Like 2
  • 2 months later...
Nice Work.
To fix the pixelation issue on the smoke in your destruction scene here are a few things you can do:
1) Increase Resolution
2) Change your "volume filter" parameter on the render tab of your object.  Set it to "gaussian".
3)Increase the "volume filter width" a bit to something like 1.1 or 1.2
  • 2 weeks later...
  • 1 month later...
  • 1 year later...
  • 2 weeks later...
