Houdini 17 Wishlist
LaidlawFX
Is it me or have the group nodes mulitplied like rabbits? After unifying noise, shaders, etc, I don't understand how node multiplicity makes sense elsewhere. Maybe SESI could weigh in on the thinking?
@michael yep exactly - copy/paste works well but it would even be more fluid, and exciting, to be able to drag-copy a node or bunch of nodes of the same type between networks.
there were many people telling us that the 'one node to rule them all' was often confusing and they had trouble figuring out where/what was going on, and there was interest here to split them up to make fixes/features easier to do in simpler code.
personally I find copy/paste faster, easier and far less error prone than dragging nodes around. and there would have to be lots of logic for what you want to do after the drop - copy of nodes, move nodes, make reference etc
RFE it if you think it's worth it
Warning peoples - h16 Boolean has 4 aliases in the viewport!!! run for the hills as y'all be confused and annoyed by this duplication - hahaha
Make the poly split node handle multiple splits under one node. Just have the split operations appear as a list in the node's Parameter window, or display them in the group/expression slot ( 1-2, 4-7, 12-63 etc ). Color code the newly generated edges when the node is selected and if the user hovers the cursor over any split edge,  the group list automatically highlights the connected points/edges/faces. The user can then remove them from the list and thus undo that particular split ( without having to invoke a blast node )
'Ignore point connectivity' in Edit SOP is a mess.
We need something more intelligent along the lines of edge detection.
It's very hard to create nice mouth and eyelid blend shapes on high density geometry with the current method.
This is a very long standing RFE (ID: 72902)
Old thread about this.
https://www.sidefx.com/forum/topic/5114/
Edited by Werner
image upload
  • Like 2
  On 3/9/2017 at 7:18 AM, marty said:
@kev2 the yellow bypass toggle does that.
Oops. I meant a single merge node connection, not the entire merge node. I realize that the switch does that but I often want to audition different inbound pipes to a merge node without running around setting the display flag. I edited the post to make more sense.
  On 3/16/2017 at 9:59 AM, sebkaine said:
ALT+E in a wrangle open the editor define in $EDITOR directly.
At the moment to open your editor you have to use the redundant 2 * ALT+E.
I'm torn by this one as it always used to annoy me that I had to go through an interim step of opening the Houdini text editor before Sublime Text but as I've become more adventurous with VEX I've come to rely on the error messages in the Houdini text editor.
Maybe an option to open both windows at the same time when using ALT E.
in fact jonathan that might be better to be able to use an other var like $SNIPPET
- to allow people who like to keep the current state in snippet to use only $EDITOR,
- and those who want to open sublime directly in a wrangle to define also $SNIPPET to sublime.
Edited by sebkaine
It would be nice to iron out the delay in Mantra starting a new frame. This slight pause adds a lot of accumulated time when the actual frame is quick to render. GPU renderers excel at this. They kick off the next frame instantly.
I'd very much like to see the new Hair system continuing to be improved in both performance - reduce the lag of brushes, decrease cooking speed, etc - as well as features. Regarding features for example, the new system no longer allows the user to use a texture-map or a paint sop for using as a multiplier for the thickness ramp, might be possible following Jeff' suggestions (on sidefx forums) but it's akin to masochism as far as I'm concerned. I'm looking for high-level tools to help do the thing quickly, while also allowing for going in depth to low-lvl for TAs that like tinkering, but Houdini's already good at this. The old Hair system also had a feature called "guard hairs" which is no longer present as far as I'm able to figure. Might be able to achieve the same effect by randomizing length, don't know, but the old method felt a bit more straight forward.
I've started working on a model with which I intend to "drive test" the new system so that I'll be able to give a more detailed feedback while learning more about it.
Something else I'd like to see in the very next H version, is a foot on the gas pedal regarding implementing modeling and viewport features. If the current speed is maintained, 2023 seems like a realistic ETA for when I'll be able to use Houdini as proficiently as XSI for modeling and other viewport centered work. Speaking for myself here obviously.
Edited by McNistor
