Controlling Focus Distance
Hey,
This is how I control the focus distance in Maya. I use a measure distance node, then use that distance to drive the focal distance so where ever I move the null, the scene is in focus. Can I do this in Houdini? Is there a measure distance node that can get the distance between two null objects? One null would be at camera's position and the other null where I want to focus.
Thanks
9 hours ago, ejr32123 said:
Hey,
Thanks
Hey,
Also , you can find the distance between camera and arbitrary point in SOP level and then fetch it as your Focus distance value.
See attached example.
Hope it help.
focus_distance1.hipnc
Edited by MagicRej
2 hours ago, Thomas Helzle said:
What I really miss is a way to click into the rendering to set the focus distance. This is very nice for quickly finding the sweet spot for stills. Love it in Thea Render etc.
Is there a way to do this as a viewport action in Houdini with some raytracing from the mouse?
Cheers,
Tom
Indeed there is. Just to illustrate a concept:
- copy $HFS/scripts/ipr/pickpixel.py to ~/houdini16/scripts/ipr/
- comment out the very last line (hou.ui.displyMessage(...))
- append (in the same scope, just bellow):
    if not "Pz" in viewer.planes():
        rop_node_name.parm("vm_quickplane_Pz").set(1)
        viewer.startRender()
    else:
        value  = viewer.pixel("Pz", px, py)
        camera = rop_node_name.parm("camera").eval()
        camera = hou.node(camera)
        camera.parm("focus").set(value[0])
For a first time you will have to Ctrl-Click twice if there is no "Pz" plane, otherwise Ctrl-click on IPR pane will set distance on rop's camera.
cheers,
skk.
  • Thanks 2
14 minutes ago, Thomas Helzle said:
Thanks symek - have to try that.
I guess that will only work with Mantra, right?
You're welcome :). I think the only Mantra dependency is adding Pz to planes' set. Otherwise it relies only on pixel value from a viewer, so if only your renderer puts some pixels there it's should work for it too.
  • Thanks 1
Cool - have to try it with Redshift as soon as the current job is done! :-)
So far I always used this in the focus distance field:
// Camera focus distance to a null called focus:
vlength(vtorigin(".","../focus"))
But it's a bit clumsy to navigate the null.
Tom
Edited by Thomas Helzle
  • Like 2
  • 6 months later...
Tom
Is this supposed to work still?
It errors out due to infinite recursion in 16.5.378
The chop expression way also does not evaluate.
Works for me in the same version you use.
Did you parent the null to something that it creates a loop? I just use a camera and a null on the obj top level.
I totally lost track of this but now finally tried it out - works great, but only for Mantra.
With Redshift I get the Python error:
So I guess Redshift (2.5.62) doesn't provide the needed handles (Houdini 16.5.378).
I'll probably have to wait for their render viewer to provide this natively.
Cheers,
Tom
It's because adding Pz/Depth extra plane for Redshift works differently. Possibly camera parameter might have different name on RS rop. It's an easy fix if you have RS around (I don't till Monday, sorry).
skk.
damn you OSX with no X server anymore.
skk.
Thank you symek and no hurry at all!
Redshift can use the Mantra camera parameters (which is what I tried) so that shouldn't be the issue.
I also tried to create a Z-Depth AOV in Redshift to no avail.
I never used python scripting in Houdini so am a bit out of my depth... :-)
Thanks and Cheers,
Tom
ye all good, thanks for responding! was testing the expression in the 'tz' channel lol
  • 5 months later...
I found another way of doing it. I know its been a while : )
1. Using add sop create a point
2. copy relative references of camera's transform to the point
3. create another point using the add node and merge the two points
4. create another add node after the merge and go to polygons, then by group. This will create a line between the first and second point.
5. create a measure sop and set type to perimeter
6. attribute promote and promote perimeter to detail
7. on cameras focus distance use the detail hscript expression, it should look like this: detail("/obj/geo1/attribpromote1/", "perimeter",0)
8.There ya go! You can move the second point around using a transform
  • 8 months later...
Have you guys manage to make this work with redshift eventually?
Thanks and Cheers,
Tom
I recently looked into it again and found a workaround that works for my uses:
I render a Z-Depth AOV set to mimimal distance with my image.
This allows to pick the Z-Depth in the Redshift viewers sidebar.
I then enter the value by hand in the camera.
Still hoping for a direct option at one point though.
The other things I looked at either didn't update at all without a manual refresh or triggered a full scene reload.
Maybe we should bug Juanjo once more... :-)
Cheers,
Tom
