Vray for Houdini
If anyone happens to have an issue with the IPR not working when using the houdini.env setup, the following fixed it for me:
Instead of :
PATH="${PATH};${VFH_PATH}"
As suggested, expand everything.
So:
PATH="${VRAY_APPSDK}\bin;${VFH_ROOT}\vfh_home\bin;$PATH;${VRAY_FOR_HOUDINI_AURA_LOADERS}"
  • Thanks 2
2 hours ago, Jesper Rahlff said:
big question for me would be if Vray is still faster rendering volumes.. Not sure it would be. Mantra is not doing to bad when it comes to volumes
I think Mantra is faster when rendering volumes, but the main issue is when you need multiple-scatter; Right now the path tracing alternative to point clouds is extremely slow in comparison with Arnold for example. Lets hope that H17 surprise us with some improvements for Mantra in volumetric rendering.
On 8/12/2018 at 3:04 AM, Joss said:
I'm having an issue with materials actually...is it just me have like 5 aux nodes in vray mat builder?
I mean there's no even textures, so I'm assuming it's either my setup or no one have them.
Not sure what you mean about 5 aux nodes, but I do have duplicated nodes. Pointed it out in the forums and there working on it.
Edited by hoi
Unreasonable
It was a bug with houdini.prefs file, generated by Houdini itself(i.e. not modified by anyone).
Something in this file made Houdini to show me just like 5 auxiliary nodes in Vray MatBuilder, like 'transform' or 'null' or 'merge' and that's it, nothing more.
When I deleted it and it was regenerated by Hou, I got all VRay nodes back.
Bug filed to Chaos.
