Popular Post DaJuice Posted December 9, 2018 Popular Post Share Posted December 9, 2018 (edited) Hi everyone, At this link you'll find three new color schemes: Ash-Smoke-Soot.zip They are meant to be flatter and a bit more subtle compared to the standard themes. Smoke has similar values to the Houdini Dark theme, Soot is a bit darker and more desaturated, and Ash is a replacement for the Houdini Pro theme. Please let me know if you discover any usability issues or ugliness and I will do my best to update the file above. I'm 100% certain that I've overlooked some things... quite possibly obvious things. Edit 12/15/18 - Updated Ash theme to fix audio waveform visibility in playbar and visibility issues with node wires and node secondary text. Edited December 24, 2019 by DaJuice 8 2 Quote Link to comment Share on other sites More sharing options...
bunker Posted December 9, 2018 Share Posted December 9, 2018 you should make "Ash" a bit darker and name it "Prisms" Quote Link to comment Share on other sites More sharing options...
pabcou Posted December 10, 2018 Share Posted December 10, 2018 Thank you for sharing them! I find Smoke very pleasing. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted December 11, 2018 Share Posted December 11, 2018 Good work! But a flat version of "Houdini Light" would be great, as well (like "Ash" but brighter). And maybe try to get rid of the dull orange you get when hovering over menus. Quote Link to comment Share on other sites More sharing options...
DaJuice Posted December 15, 2018 Author Share Posted December 15, 2018 Thanks for the feedback. Konstantin, I'm surprised. I didn't bother with a light theme because I didn't think people used them. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted December 15, 2018 Share Posted December 15, 2018 I know its unusual and probably a bit retro, but at daytime or during presentations its sometimes good to have a little more contrast, I think. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted December 17, 2018 Share Posted December 17, 2018 I like Soot. Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 6, 2019 Share Posted August 6, 2019 Smoke is very well done Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 6, 2019 Share Posted August 6, 2019 (edited) II've found a 3DSceneColors.bw in the zip file, I put it in config folder but I can't see no changes in viewport darkmode ? even the node graph no changes ? Edited August 6, 2019 by davidyannick infos missing Quote Link to comment Share on other sites More sharing options...
DaJuice Posted August 6, 2019 Author Share Posted August 6, 2019 Hi David, 3DSceneColors.bw changes the color for the "Grey" viewport background (Viewport display options > Background > Color Scheme: Grey). Your Houdini install also includes 3DSceneColors.light and 3DSceneColors.dark for the Light and Dark viewport backgrounds, but they are not being modified by these themes. 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted August 6, 2019 Share Posted August 6, 2019 53 minutes ago, DaJuice said: Hi David, 3DSceneColors.bw changes the color for the "Grey" viewport background (Viewport display options > Background > Color Scheme: Grey). Your Houdini install also includes 3DSceneColors.light and 3DSceneColors.dark for the Light and Dark viewport backgrounds, but they are not being modified by these themes. Ok thank you 1 Quote Link to comment Share on other sites More sharing options...
lepetitnono Posted August 29, 2019 Share Posted August 29, 2019 (edited) Hello DaJuice, Thanks for this smoke super theme, it rocks ! it's cleaner and more serious looking too ! Now i'd like to change the default color for every new node created in every new hip file, seems that by default the nodes color is set at about GREY(0.7) but i'd like to have my every created nodes at GREY(0.2) or DARK I've looked inside the ST-Smoke.hcs did not found the correct name for what i'm looking for, may you please help me by answering with the correct name ? or a technique to change this default base color for every new node ? Thanks ++ Edited August 29, 2019 by lepetitnono Quote Link to comment Share on other sites More sharing options...
DaJuice Posted August 30, 2019 Author Share Posted August 30, 2019 Hi lepetitnono, I'm glad you like the theme! Changing default node colors is done inside of Houdini: http://www.sidefx.com/docs/houdini/network/organize#themes With your mouse over the network view hit 'd' to bring up the display options. Go to the Themes tab, click on the Default Node Colors drop down menu and duplicate one of the standard themes. Hit 'c' in network view to bring up your color palette. Ctrl drag and drop a color swatch onto your node. That color is now the default for that node type (geometry, light, camera, etc). You can right-click and add additional colors to the color palette. Hope that helps. Quote Link to comment Share on other sites More sharing options...
lepetitnono Posted September 1, 2019 Share Posted September 1, 2019 (edited) thanks a lot DaJuice, I knew this, but it is not exactly what i was looking for, this is usefull is you want to customise one node at a time but i'd like to have them all tinted in a more dark grey as default, then from that point, i'd apply custom colors for each node that need it > say dopnet popnet null and so... There is no way to apply one color for every nodes ? thank you. What i do is then adding nodes after nodes, scenes after scenes the new color for the nodes manually > ctrl on color and apply to nodes, then dupplicate the default nodes colors in themes ../ Network view display options and giving it the same name, so it adds the new colors to the current theme colors. Edited September 1, 2019 by lepetitnono Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted November 16, 2019 Share Posted November 16, 2019 @DaJuice I put the theme colors into the /config sub-folder but my icons are not changing, in this case to the look of the soot theme ? Quote Link to comment Share on other sites More sharing options...
matEvil Posted November 16, 2019 Share Posted November 16, 2019 thanks for share it, I try soon. Matteo Quote Link to comment Share on other sites More sharing options...
DaJuice Posted December 1, 2019 Author Share Posted December 1, 2019 Apologies for the late replies. On 9/1/2019 at 3:23 AM, lepetitnono said: What i do is then adding nodes after nodes, scenes after scenes the new color for the nodes manually > ctrl on color and apply to nodes, then dupplicate the default nodes colors in themes ../ Network view display options and giving it the same name, so it adds the new colors to the current theme colors. I looked in the config folder and I didn't notice anything that might allow you to change all node colors at once. When you say "scene after scene" do you mean that your icon color customization doesn't stick between Houdini sessions? On 11/16/2019 at 5:35 AM, CinnamonMetal said: @DaJuice I put the theme colors into the /config sub-folder but my icons are not changing, in this case to the look of the soot theme ? @CinnamonMetal are you still having this issue? I'm not sure why that might be the case. The icon colors are being modified by four lines in the .hcs files. For Soot: // Color correction for the icons -------------------------------------------- IconBrightness: .85 IconContrast: 1 IconGamma: 1 IconSaturation: 0.3 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted December 2, 2019 Share Posted December 2, 2019 @DaJuice Yes, I'm still facing issues; hopefully you can help me to get this working ? Quote Link to comment Share on other sites More sharing options...
DaJuice Posted December 2, 2019 Author Share Posted December 2, 2019 @lepetitnono I spoke too soon. When you create a custom node color theme it will create a new file in your $HOME directory, for example named Custom_theme.nodecolors. Inside, the different node type are listed along with corresponding RGB values, and you can modify everything there. @CinnamonMetal Please try to temporarily rename your Houdini home directory so a fresh new preferences folder is created. Then go ahead and copy over the color theme files and see if the results are any different. Also be sure to update the #include line at the top of each .hcs file to point to the correct Houdini version. That won't affect the icon saturation issue, just network pane colors. Quote Link to comment Share on other sites More sharing options...
davidyannick Posted February 11, 2021 Share Posted February 11, 2021 On 02/12/2019 at 4:02 PM, DaJuice said: @lepetitnono I spoke too soon. When you create a custom node color theme it will create a new file in your $HOME directory, for example named Custom_theme.nodecolors. Inside, the different node type are listed along with corresponding RGB values, and you can modify everything there. @CinnamonMetal Please try to temporarily rename your Houdini home directory so a fresh new preferences folder is created. Then go ahead and copy over the color theme files and see if the results are any different. Also be sure to update the #include line at the top of each .hcs file to point to the correct Houdini version. That won't affect the icon saturation issue, just network pane colors. I'd like to customize Smoke theme but can you tell me what are the parameter to modify to have blue instead of orange like in this screenshot ? Thank you Quote Link to comment Share on other sites More sharing options...
