Posted (edited)
Hello all,
I'm attempting to make an effect like this and am getting stumped if anyone had any ideas on how to approach it would be super helpful!
Thanks.
Edited by jonidunno
Share this post
Link to post
6 hours ago, srletak said:
Use iso surface :wub:
Yes I would assume something along those lines. but i cannot figure out the extrusion process.
Share this post
Link to post
Play with converting a vector field to polygons. Start with straight up normalized -1,-1,-1 to 1,1,1 noise and go from there.
Share this post
Link to post
you can use a pointcloud node aswell. After this you can apply a volume wrangle on it, which is more comfortable to define scalar fields. Now you can use volume convert, which converts your cloud(field) into an isosurface.
The standard convert + fuse will create polygons, which can be used for boolean (or other) operations.
Applying for each node with different iso levels, will give different iso surfaces.
The main problem is finding the right iso function and parameters. There are many possibilities. And even if you have the right values the effect needs more to look equal.
If interested, here is a rough approach getting iso surfaces
iso_X.hipnc
  • Thanks 1
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
