Adam Ferestad Posted December 11, 2019 Share Posted December 11, 2019 So I am trying to put together a basic test scene for work. Just a box, a grid, a light, and a camera, and I cannot for the life of me get the lighting to render. pxr lights aren't doing anything, Houdini lights aren't doing anything. Nothing. The RIS node only wants to render the headlight. What am I missing? Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted January 1, 2020 Share Posted January 1, 2020 On 12/11/2019 at 6:23 PM, Adam Ferestad said: So I am trying to put together a basic test scene for work. Just a box, a grid, a light, and a camera, and I cannot for the life of me get the lighting to render. pxr lights aren't doing anything, Houdini lights aren't doing anything. Nothing. The RIS node only wants to render the headlight. What am I missing? Expand Prx lights in sop context work. Did you choose a material? What is a little bit cumbersome is the placement of the lights, because one handle of the two doe not work correctly as it seems. If it does not work for you, perhaps reinstall RM 23. Quote Link to comment Share on other sites More sharing options...
akelian Posted May 20, 2020 Share Posted May 20, 2020 If you are not using the shelf tools you need to setup the integrator yourself. Quote Link to comment Share on other sites More sharing options...
Atom Posted May 20, 2020 Share Posted May 20, 2020 I had the same problem, RIS doesn't seem to work anymore in H18. The renderman delegate does work under LOPs, however. Give that a try. Quote Link to comment Share on other sites More sharing options...
schwungsau Posted May 22, 2020 Share Posted May 22, 2020 it works perfectly fine here with houdini18. you have make sure you using RM23 shelf / nodes. if you see only RIS only the renderman plugin is not corrected loaded. Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted June 25, 2020 Share Posted June 25, 2020 how did you output a renderman usd graph? i dont seem to have a renderman/prman lop unlike karma Quote Link to comment Share on other sites More sharing options...
DaJuice Posted June 25, 2020 Share Posted June 25, 2020 It's possible that Pixar will implement their own output LOP (I believe RS and 3Delight already plan to) but for now I think you have to use a USD Render ROP LOP in conjunction with the Render Settings LOP. Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted June 26, 2020 Share Posted June 26, 2020 ok, i seem to miss a new env called RFHTREE, which loads the renderman lops and other stuff, seems really buggy though pxr material builder always crash, ill do karma for now Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted June 26, 2020 Share Posted June 26, 2020 On 6/25/2020 at 4:40 PM, DaJuice said: It's possible that Pixar will implement their own output LOP (I believe RS and 3Delight already plan to) but for now I think you have to use a USD Render ROP LOP in conjunction with the Render Settings LOP. Expand this works btw Quote Link to comment Share on other sites More sharing options...
Sakib Khondaker Posted March 2, 2022 Share Posted March 2, 2022 You have to manually link the Integrator = /shop/risnet1/pxrpathtracer1 Quote Link to comment Share on other sites More sharing options...
