Etienne Posted December 17, 2019 Share Posted December 17, 2019 So, I have this... I want to delete points at the corner. I'm using a sphere, copy to points on my first ADD that have the corner points I need to remove. I have created a group name corner points using Bounding Object as Bounding type. but the group as nothing selected. Can someone point me out where I might have gone wrong please. Thanks. Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted December 17, 2019 Share Posted December 17, 2019 Set your sphere to mesh or polygon. Quote Link to comment Share on other sites More sharing options...
Etienne Posted December 17, 2019 Author Share Posted December 17, 2019 @ThomasPara I just did and didnt seem to work... Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted December 17, 2019 Share Posted December 17, 2019 instead you can use a pointwrangle, input your points in the first input, and your cornerpoints in the second. int nearpt = nearpoint(1,@P,0.0001); if(nearpt >= 0){ i@group_corners = 1; } Quote Link to comment Share on other sites More sharing options...
anim Posted December 17, 2019 Share Posted December 17, 2019 while even primitive shperes should work, it's difficult to see what's wrong with your scene just from screenshots alternatively you can use Group Expression (or wrangle) nearpoint(1, @P, 0.01) != -1 where 0.01 is you threshold which means that only points within this threshold distance from points in second input will be in the group select_points_by_second_input.hip Quote Link to comment Share on other sites More sharing options...
Etienne Posted December 17, 2019 Author Share Posted December 17, 2019 @ThomasPara I'm not sure if I fallow you. Something like this.. Quote Link to comment Share on other sites More sharing options...
Etienne Posted December 17, 2019 Author Share Posted December 17, 2019 Here the file. Will be more easier to see whats wrong. House_gen.hipnc Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted December 17, 2019 Share Posted December 17, 2019 You can identify corner points on flat polygons by their tangents' length between two edges using the polyframe node. corners.hipnc Quote Link to comment Share on other sites More sharing options...
Etienne Posted December 17, 2019 Author Share Posted December 17, 2019 (edited) I am fallowing this video. at 46 minutes my group just do not work. House_gen.hipncFetching info... Edited December 17, 2019 by Etienne Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 17, 2019 Share Posted December 17, 2019 Not sure why isn't working with the ctp as it is, if you use a transform and move the sphere to the pt it works as well. Anyway, for now if you add a vdbfrompolys after the ctp it works. This might be a bug so it might good to report it. Quote Link to comment Share on other sites More sharing options...
ftaswin Posted December 18, 2019 Share Posted December 18, 2019 For your case, this works (run on point wrangler): int pts[] = neighbours(0,@ptnum); if(len(pts)!=2) return; vector n1 = normalize(point(0,"P",pts[0])-@P); vector n2 = normalize(point(0,"P",pts[1])-@P); @group_corners = dot(n1,n2)>-0.1; Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 18, 2019 Share Posted December 18, 2019 methinks there's a bug with the resample ? simple example, lowres circle, group all points as orig. resample, now select the orig group....they ALL light up...not kosher I don't think. vu_resample_bug.hiplc Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 18, 2019 Share Posted December 18, 2019 The spheres / bounding objects is not necessary anyway. Just group the corner points at a point in your workflow when you have just them, then group transfer said group to the refined geo. Then groupcombine to invert the group and you have the notcorners group.. Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 18, 2019 Share Posted December 18, 2019 (edited) On 12/18/2019 at 4:52 AM, Noobini said: methinks there's a bug with the resample ? simple example, lowres circle, group all points as orig. resample, now select the orig group....they ALL light up...not kosher I don't think. vu_resample_bug.hiplcFetching info... Expand I didn't find any references in the doc on the subject of how the attributes or group are handled during a resample. I know the attributes are linearly interpolated, but it's unclear how the groups are interpolated, whether in resample or subdivide. However, it can be emulated using a float attribute.. FWIW: the point groups are correctly interpolated in "Treat polygon As: Straight Edges" mode, and not in the two other ones (Subdivision, Interpolate) Edited December 18, 2019 by AntoineSfx Quote Link to comment Share on other sites More sharing options...
Etienne Posted December 18, 2019 Author Share Posted December 18, 2019 @Sepu Thanks alot, using a VDBFromPoly works! :) Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 18, 2019 Share Posted December 18, 2019 (edited) On 12/17/2019 at 6:39 PM, Etienne said: I am fallowing this video. at 46 minutes my group just do not work. House_gen.hipncFetching info... Expand You have almost duplicate points in Add1 because of Facet1 (unique points) The bounding object in group1/ input2 is made of non connected and overlapping geometries. Each sphere is present twice, and it's causing problems in the algorithm they're using to test if a point is inside a bounding object or not. See https://en.wikipedia.org/wiki/Point_in_polygon for the reason why two overlapping spheres will cause points at their intersection being incorrectly seen as outside. The VDB From Poly is "solving" this by merging the two identical spheres together and makes the geometry nice and clean. Edited December 18, 2019 by AntoineSfx Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 18, 2019 Share Posted December 18, 2019 On 12/18/2019 at 1:58 PM, AntoineSfx said: I didn't find any references in the doc on the subject of how the attributes or group are handled during a resample. I know the attributes are linearly interpolated, but it's unclear how the groups are interpolated, whether in resample or subdivide. However, it can be emulated using a float attribute.. FWIW: the point groups are correctly interpolated in "Treat polygon As: Straight Edges" mode, and not in the two other ones (Subdivision, Interpolate) Expand well Treat polygon as straight edges is STILL wrong for me. Anyway, to me it's far more logical to NOT auto lump any new geo into existing groups...just me. Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 18, 2019 Share Posted December 18, 2019 Quote Link to comment Share on other sites More sharing options...
