DHartleRyan 5 Posted August 6, 2020 Hey, here's a project I've been working on for a long time, procedural Jellyfish with procedural animation based on source points. Please let me know how I can improve this. DHR Share this post Link to post Share on other sites
Librarian 634 Posted August 6, 2020 try too feed some motion with chops if you already not doing that Share this post Link to post Share on other sites
DHartleRyan 5 Posted August 7, 2020 14 hours ago, Librarian said: try too feed some motion with chops if you already not doing that Hey librarian How do you mean? Share this post Link to post Share on other sites
Librarian 634 Posted August 7, 2020 https://lesterbanks.com/2017/03/using-chops-rigging-houdini/ Or post just ONE Jellyfish (now I'm owner of indie Houdini 18 and have solid PC) I can surely Help or I just want your file .you never know!!! Share this post Link to post Share on other sites
DonRomano 63 Posted August 7, 2020 You may add a seabed to add depth to your ocean and make it believable, and also work the lighting (you can add godrays, fog) and rework the shading of your water surface. Look at some reference ! Here we see clearly how gradually the "fog" blurs and hide the seabed and the ocean surface gradually. The motion looks good to me, but adding an environment (quixel is your friend ) may hugely imrove your render ! Cheers, Share this post Link to post Share on other sites
DHartleRyan 5 Posted August 7, 2020 9 minutes ago, Librarian said: https://lesterbanks.com/2017/03/using-chops-rigging-houdini/ Or post just ONE Jellyfish (now I'm owner of indie Houdini 18 and have solid PC) I can surely Help or I just want your file .you never know!!! Nice i will check that out after work. I'll try set up a file for you to check out, at the moment it has a lot of cached stages. Its not rigged in a conventional sense, just one line animated, altered in chops depending on the particles speed, copied round and delayed based on a noise attribute, then skinned and extruded. Share this post Link to post Share on other sites
DHartleRyan 5 Posted August 7, 2020 4 minutes ago, DonRomano said: You may add a seabed to add depth to your ocean and make it believable, and also work the lighting (you can add godrays, fog) and rework the shading of your water surface. Look at some reference ! Here we see clearly how gradually the "fog" blurs and hide the seabed and the ocean surface gradually. The motion looks good to me, but adding an environment (quixel is your friend ) may hugely imrove your render ! Cheers, I was having some trouble with the redshift environment volume and god rays when i added a floor but i think it really would benefit from an ocean floor environment like you say. The gradual blur across the sea is a really good point as well. Thank you Share this post Link to post Share on other sites
DonRomano 63 Posted August 7, 2020 Few tips for volumetric lighting with redshift : - Apply a material to the tint shader of the fog (../redhift_rop/redshift/volumetric scattering) and plug your nodes to the volume output of your shader, this allows you to add noise to the fog and/or any other operation you want (like for example get the camera position and create a gradient from the camera position to remap the fog density based on the distance from the camera to get the desired effect) - Use gobo shaders in your spotlights to get better god rays. It's pretty easy to create some gobo maps in photoshop with textures and filters - Create your own volume effects in sops with volume vops, it can be very cool to have some slightly moving volume just on top of the seabed to simulate water flowing and moving sand grains During the week-end if I have time I may help you, do not hesitate to reach me out Cheers, Share this post Link to post Share on other sites
