Randomly scale down particles with a linear field
sunlight90
I have particles in my scene. I want to fade out my particles pscale based on controller geo and a falloff. But I want to add a bit randomness to it.
In cinema 4d I would just grab a linear field and a random field.
In Houdini, my plan was to use a grid with maskfromgeometry and attribtransfer that on the particles. However, this will just scale down all the particles that are in one axis the same way. I have no idea how to add randomness on the particles scale, (I want that some particles scale down faster, and some particles need longer to be scaled down)
Thank you. Instead of linking it to the time, I've linked it to my controller geo. The particles fade out with random values,  but they still fade out all at once in a straight line as you can see.
My goal is to let some particles fade out later than others, so that I break this linear outfade shape. I've tried to sketch that in red.
Hi Karsten,
here is a remotely similar example. It's scaling a point grid by proximity to several planes (represented by the large points and their normals).
int pt_near = nearpoint(1, v@P);
vector clr_near = point(1, 'Cd', pt_near);
vector pos_plane = point(1, 'P', pt_near);
vector nml_plane = normalize(pos_plane);
float dist = planepointdistance(pos_plane, nml_plane, v@P, set(0));
scale_by_plane_dist.hipnc
Expand
You can modify it easy to get what you want
int f = rint(fit01(rand(@id),0,20));
int rnd = rint(fit01(rand(@id+54),0,20));
float p = fit(@Frame,f,f+rnd,1,0);
@pscale*=p;
