Transfering attributes issue...
20 hours ago, jfaulkner said:
What you could try instead is to transfer the attributes before a solver, and then use a solver after to merge the attributes together.
attached should hopefully solve your question! :D
AttributeTransfer_02.hiplc
Hi James,
Thanks for the reply. The "max()" function inside the Solver node changes the value of the transforming attribute and it doesn't work for me.
I think your premise is that the sphere is solid red all the way through, when in reality it is only red on those thin polygon surfaces. You have to help out the attribute transfer node by filling the sphere with red points.
Edited by Atom
