Vellum un-pin by attribute, issue!
Masoud
Hi guys
In a vellum simulation, I want to un-pin objects over time, using an attribute (I set "stopped=1" on selected points).
So I tried to transfer the "stopped=0" attribute, using an "SOP Solver", inside the DOPs.
Everything is okay, but in the future, I need more sub-steps, and by increasing the sub-step (to 2 or more), the vellum objects start to jiggle.
How can I fix it?
Thanks for helping
Vellum_Hairs_01.hip
you can also use an intermittent solve dop node after your sop solver and keep the default setting to "solve every 1 frame" if its your sopsolver causing the issues
that way your sop solver only evaluates once every frame even though your whole dopnet runs at multiple substeps.
Edited by Jesper Rahlff
