Jason Posted August 13, 2003 Share Posted August 13, 2003 If you can, download it from http://www.vislab.usyd.edu.au/sidefx - it's a slightly newer version. Oh, and welcome to odforce! We hope you enjoy Houdini and all. Quote Link to comment Share on other sites More sharing options...
michael Posted August 13, 2003 Share Posted August 13, 2003 you can stop by the SESI offices and pick up a copy of the Apprentice Edition - if you want to get the quick reference card...but the version at Vislab is the latest Quote Link to comment Share on other sites More sharing options...
NatXotic Posted August 16, 2003 Share Posted August 16, 2003 Newest Build 101 is out on vislab site. Quote Link to comment Share on other sites More sharing options...
capinXcrunch Posted August 27, 2003 Share Posted August 27, 2003 Dinners readdddddyyyy... Fresh from the oven: http://www.vislab.usyd.edu.au/sidefx/cd1_6.1.114/ 6.1.114 Quote Link to comment Share on other sites More sharing options...
athomas Posted August 27, 2003 Share Posted August 27, 2003 I've got to say I've never experienced that quick of update versions being available. Got to install a new version every other week (not complaining though) Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 27, 2003 Share Posted August 27, 2003 Oohh! Does sidefx release a changelog anywhere? --Ronnie Quote Link to comment Share on other sites More sharing options...
rebo Posted August 27, 2003 Share Posted August 27, 2003 I was just about to post that exact same question concept4 =] Quote Link to comment Share on other sites More sharing options...
michael Posted August 27, 2003 Share Posted August 27, 2003 there is one but it's not made available to Apprentice users, AFAIK. Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted August 28, 2003 Share Posted August 28, 2003 Well... that's unfair! Anyone can see from Early Access forum on SideFX's site that Apprentice users contribute alot by submitting bugs. Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted August 28, 2003 Share Posted August 28, 2003 Well... that's unfair!Anyone can see from Early Access forum on SideFX's site that Apprentice users contribute alot by submitting bugs. Twas me. Forgot to log in. Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted August 28, 2003 Share Posted August 28, 2003 Dammit! It was "Stremik" What's the deal?! I'm logging in and it redirects me to a main forums page without any error messages but I'm still not logged in! Quote Link to comment Share on other sites More sharing options...
Marc Posted August 28, 2003 Share Posted August 28, 2003 Hey Stremik ...um.... try again maybe? I've checked your settings and everything looks fine. I did switch a few things to see if it made a difference. If not, then mail me and I'll see what I can do.. Cheers Marc Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 28, 2003 Share Posted August 28, 2003 I'm in!!! Thanks Marc! Quote Link to comment Share on other sites More sharing options...
anakin78z Posted August 28, 2003 Share Posted August 28, 2003 so have you guys tried the wire deform sop? Pretty darn nifty. Quote Link to comment Share on other sites More sharing options...
Mcronin Posted August 28, 2003 Share Posted August 28, 2003 Heya Anakin, I haven't tried it yet, but I looked at it and I'm not sure how to use it, though I think I know what it's supposed to do. Would you mind giving a quick explanation of how to use the Wire Deform SOP? I think I'm going to be wanting to use it very soon. Quote Link to comment Share on other sites More sharing options...
anakin78z Posted August 28, 2003 Share Posted August 28, 2003 ok, here's the basics: the setup is similar to the lattice, so you need these ingredients: polygon surface to be deformed some curve that doesn't move attrib create to create a primitive attribute called radiusf on the curves. same curve, but deformed. now connect 'em, one two three, and you're up and running! you can play with the radiusf value to modify the falloff the effect has. -Jens Quote Link to comment Share on other sites More sharing options...
edward Posted August 29, 2003 Share Posted August 29, 2003 For good fun with the wiredeform: - try using a NURBs grid for the second and third inputs - try introducing the scalef prim attribute in the third input and varying that - try putting down a basis sop in the third input and changing the origin All this is gonna change soon though as the interface gets cleaned up and not require so much knowledge to setup. Quote Link to comment Share on other sites More sharing options...
Mcronin Posted August 29, 2003 Share Posted August 29, 2003 Thanks for the replies. I got it all hooked up like you mentioned Anakin, Poly surface into input one, NURBs curve with radiusf into input 2, deformed curve with radiusf in input 3, but it doesn't seem to work. Infact Houdni 6.1.114 keeps crashing on me whenever I try to do anything with this wiredeformer. Can I trouble someone for a working sample file so I can try to work this out? Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 29, 2003 Share Posted August 29, 2003 I wander, how many more are there OPs that haven't been added to help docs yet! Is "Wire Deform" the only one? Quote Link to comment Share on other sites More sharing options...
michael Posted August 29, 2003 Share Posted August 29, 2003 I think that's why it's called Early Access Quote Link to comment Share on other sites More sharing options...
