robert.magee Posted January 15, 2015 Share Posted January 15, 2015 SideFX is proud to release Houdini 14 - also available for Indie and Apprentice users Learn More... H14 Feature List 5 Quote Link to comment Share on other sites More sharing options...
rayman Posted January 15, 2015 Share Posted January 15, 2015 Amazing! 1 Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted January 15, 2015 Share Posted January 15, 2015 Awesome Release!! Congratulations SESI, now Houdini its a real standard in the industry! 1 Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted January 15, 2015 Share Posted January 15, 2015 Grain Object is awesome, Mantra rendering is much faster now. Great Updates Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted January 15, 2015 Share Posted January 15, 2015 It's fantastic. Love the new tools. It may take some time getting used to the hotkey changes. Quote Link to comment Share on other sites More sharing options...
mattvfx Posted January 15, 2015 Share Posted January 15, 2015 (edited) looking great good job sesi the solid object has less attributes now. is there any way to accces the old attributes(shear,volumedamp,etc)? Edited January 15, 2015 by mattvfx Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 15, 2015 Share Posted January 15, 2015 I never thought I would say this, but I´m having a blast playing with a pig´s head! Quote Link to comment Share on other sites More sharing options...
rayman Posted January 15, 2015 Share Posted January 15, 2015 (edited) The feature list is endless! I did not expected so much Bullet improvements... Its really fast now and packed object deforming options is really great! One thing I found a bit odd is the default behaviour of Constraint Network 'Override with SOP' parameter when it is created using shelf tools - simulations behaves as if this parameter is always 1 and glue net is too jittery. Anyway I set it to 0 and everything is back to normal. No time to sleep.. Edited January 15, 2015 by rayman Quote Link to comment Share on other sites More sharing options...
Skybar Posted January 15, 2015 Share Posted January 15, 2015 Can't wait to try it out! Amazing stuff! Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 15, 2015 Share Posted January 15, 2015 Documentation New Changes http://www.sidefx.com/docs/houdini14.0/news/14/ Houdini 14 Features Videos - Houdini 14 Overview - - Animation Layers - - Asset Menu - - Character Picker - - Component Selection - - Create Camera - - Create Projects - - Creating Objects - - Crowd Intro - - Display Options - - Dry Sand - https://vimeo.com/116602069 - Edge Smoothness - https://vimeo.com/116797433 - Edgeloop Selections - https://vimeo.com/113102820 - Emitting Particles - https://vimeo.com/113730728 - FLIP Fluids - https://vimeo.com/116176349 - Granular Solid - https://vimeo.com/116886314 - Grooming Hair I - https://vimeo.com/116178807 - Hair Grooming II - https://vimeo.com/116889293 - Hair Transfer - https://vimeo.com/116797623 - Motion Path Animation - https://vimeo.com/116174690 - Navigating Networks - https://vimeo.com/113734706 - Network View - https://vimeo.com/113735042 - Panes and Pane tabs - https://vimeo.com/113096230 - Poly Reduce - https://vimeo.com/116797694 - RBD Instance - https://vimeo.com/113103248 - Revolve a Curve - https://vimeo.com/116173025 - Set Keyframe - https://vimeo.com/116173730 - Snapping - https://vimeo.com/113735437 - Transforming Objects - https://vimeo.com/113103062 - UV Flatten - https://vimeo.com/116671338 - UV Layout - https://vimeo.com/116671421 - View Tools - https://vimeo.com/112743547 - Wet Sand - https://vimeo.com/116602271 - Workspace - https://vimeo.com/113734396 New Tutorial Series - Houdini Projects: Terrain Generation 1 - https://vimeo.com/116364169 - Houdini Projects: Terrain Generation 2 - https://vimeo.com/116364341 Quote Link to comment Share on other sites More sharing options...
cwhite Posted January 15, 2015 Share Posted January 15, 2015 One thing I found a bit odd is the default behaviour of Constraint Network 'Override with SOP' parameter when it is created using shelf tools - simulations behaves as if this parameter is always 1 and glue net is too jittery. Anyway I set it to 0 and everything is back to normal. The new default expression for that parameter tries to be more user-friendly - it detects whether the SOP path is time dependent, and it will re-import the geometry on each frame for you if that's the case. Using the shelf tools on a shattered torus works as expected for me - the parameter evaluates to 1 on the first frame and 0 afterwards - what steps did you take to encounter that issue? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 15, 2015 Share Posted January 15, 2015 A conviennent page also has these... https://www.sidefx.com/index.php?option=com_content&task=blogcategory&id=247&Itemid=403 Documentation New Changes http://www.sidefx.com/docs/houdini14.0/news/14/ Houdini 14 Features Videos - Houdini 14 Overview - - Animation Layers - - Asset Menu - - Character Picker - - Component Selection - - Create Camera - - Create Projects - - Creating Objects - - Crowd Intro - - Display Options - - Dry Sand - https://vimeo.com/116602069 - Edge Smoothness - https://vimeo.com/116797433 - Edgeloop Selections - https://vimeo.com/113102820 - Emitting Particles - https://vimeo.com/113730728 - FLIP Fluids - https://vimeo.com/116176349 - Granular Solid - https://vimeo.com/116886314 - Grooming Hair I - https://vimeo.com/116178807 - Hair Grooming II - https://vimeo.com/116889293 - Hair Transfer - https://vimeo.com/116797623 - Motion Path Animation - https://vimeo.com/116174690 - Navigating Networks - https://vimeo.com/113734706 - Network View - https://vimeo.com/113735042 - Panes and Pane tabs - https://vimeo.com/113096230 - Poly Reduce - https://vimeo.com/116797694 - RBD Instance - https://vimeo.com/113103248 - Revolve a Curve - https://vimeo.com/116173025 - Set Keyframe - https://vimeo.com/116173730 - Snapping - https://vimeo.com/113735437 - Transforming Objects - https://vimeo.com/113103062 - UV Flatten - https://vimeo.com/116671338 - UV Layout - https://vimeo.com/116671421 - View Tools - https://vimeo.com/112743547 - Wet Sand - https://vimeo.com/116602271 - Workspace - https://vimeo.com/113734396 New Tutorial Series - Houdini Projects: Terrain Generation 1 - https://vimeo.com/116364169 - Houdini Projects: Terrain Generation 2 - https://vimeo.com/116364341 Quote Link to comment Share on other sites More sharing options...
rayman Posted January 15, 2015 Share Posted January 15, 2015 I recreated it using only shelf tools and result is the same (OSX build) : -Create a sphere (manually) -Shatter using (shelf) -RBD Fractured object (shelf) -Ground Plane (shelf) -Glue Adjacent (shelf) DOP_glue_jitter.hipnc Quote Link to comment Share on other sites More sharing options...
magneto Posted January 16, 2015 Share Posted January 16, 2015 This release is rock solid. Right off the bat: is the font changed again? The texts seem tiny bitter smaller, almost like the kerning is smaller i.e. the text is slightly harder to read. Nothing bad really just an observation. I tried High DPI but too big for my monitor Anyone with 4K monitors can report how it looks? There is still a ton of features I want to go through but the new viewport looks light years ahead of the competition. Very slick work by Mark himself I assume Quote Link to comment Share on other sites More sharing options...
cwhite Posted January 16, 2015 Share Posted January 16, 2015 I recreated it using only shelf tools and result is the same (OSX build) : -Create a sphere (manually) -Shatter using (shelf) -RBD Fractured object (shelf) -Ground Plane (shelf) -Glue Adjacent (shelf) Thanks, I can see the re-appearing constraints with that file. I'm not sure if it's caused by that expression, but I'll look into it further... 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 16, 2015 Share Posted January 16, 2015 There is still a ton of features I want to go through but the new viewport looks light years ahead of the competition. Very slick work by Mark himself I assume On OsX the new OpenGL3+ viewport is worth the upgrade itself, but the cream is OpenCL now available also on OsX Just make sure to use Yosemite as Apple really picked their driver game up in that release Quote Link to comment Share on other sites More sharing options...
magneto Posted January 16, 2015 Share Posted January 16, 2015 (edited) On OsX the new OpenGL3+ viewport is worth the upgrade itself, but the cream is OpenCL now available also on OsX Just make sure to use Yosemite as Apple really picked their driver game up in that release I am using Win7 aka the greatest OS Also this is what I mean: I think H13 looks more readable, crisp/sharp. I assume this new change is due to Qt adoption? Personally I am not a fan of monospace fonts as seen in the node names. Also is there a way to turn off the animation that happens when you dive inside an HDA? I would also appreciate if anyone knows how to turn off the faded look of locked networks. I know it's useful but I already know if a network is locked or not, and seeing the node names clearly is more important to me. Once again one of the greatest release hands down Edited January 16, 2015 by magneto 4 Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted January 16, 2015 Share Posted January 16, 2015 Man, this change from 13-14 reminds me when 8 moved to 9! However, does anyone feel that H14's bullet simulates slower? I did a cursory test, using a hip file from H13. H14 definitely sims slower vs 13. Can't wait to test the new solvers though :3 Quote Link to comment Share on other sites More sharing options...
acey195 Posted January 16, 2015 Share Posted January 16, 2015 Also is there a way to turn off the animation that happens when you dive inside an HDA? Yes there is, in preferences/Network Editor, Nodes, and Trees/Animate Network Changes 1 Quote Link to comment Share on other sites More sharing options...
edward Posted January 16, 2015 Share Posted January 16, 2015 However, does anyone feel that H14's bullet simulates slower? I did a cursory test, using a hip file from H13. H14 definitely sims slower vs 13. Can't wait to test the new solvers though :3 If you have a file that reproduces, make sure you submit it. Quote Link to comment Share on other sites More sharing options...
