Guest tar Posted January 1, 2017 Share Posted January 1, 2017 Render frame number on the Render Manager when using the background renderer, ie 'render frame 191 (191 of 800)'. It only shows percentage currently. Rfe submitted. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted January 2, 2017 Share Posted January 2, 2017 (edited) I'm tired of fighting to get nuke license in vfx shop. That would be great if sesi could put some love in COPS, just to give us a good enough 2D comp tool that allow to ditch Nuke for 80% of our comp task. - a good enough 2D track / stab tool - optical flow tool - ofx support for frishluft / rsmb / neat - cleaner color curves UI - better hue curves UI - cleaner color correct UI with low/mid/high tone color wheel - some photographic noise / LUT tool like the one you find in octane would be nice I know i could use natron or fusion but those tool aren't mainstream, keeping all inside H would be nice ... Edited January 2, 2017 by sebkaine 3 Quote Link to comment Share on other sites More sharing options...
abvfx Posted January 2, 2017 Share Posted January 2, 2017 (edited) On 1/2/2017 at 11:14 AM, sebkaine said: That would be great if sesi could put some love in COPS, just to give us a good enough 2D comp tool that allow to ditch Nuke for 80% of our comp task. Expand Also with H being so high in the forefront of most people radar as an FX package it seems like a no brainer to give it some strong comping tools. I don't need Nuke for my everyday needs but it feels so foreign having to learn little portions just for simple things like comping little dailies/turntables etc. Much more comfortable in H. Edited January 2, 2017 by abvfx Quote Link to comment Share on other sites More sharing options...
MENOZ Posted January 2, 2017 Share Posted January 2, 2017 -built-in bend resistance in grain solver for cloth behaviour would be nice to have as well. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 2, 2017 Share Posted January 2, 2017 @sebkaine how much functionality do you want in the 2d tracker? how would you use it? Quote Link to comment Share on other sites More sharing options...
sebkaine Posted January 3, 2017 Share Posted January 3, 2017 (edited) @marty well just basic stuff. - a tracker node where you do the 2d track and store your tracks - a matchmove node where you can do matchmove and stab with 1 track -> T 2 tracks -> T + R 3 tracks -> T + R + S you can animate your roto shape / you can stab a plate / you can connect grid distorsion point to a tracker Edited January 3, 2017 by sebkaine Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 3, 2017 Share Posted January 3, 2017 @sebkaine cool - a tracker would be helpful, but most work these days really needs a 3d tracker, then a 2d track to optimise the track. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted January 3, 2017 Share Posted January 3, 2017 (edited) well 3d tracker is useful Marty but to get this in Nuke you have to go NukeX which is twice the price of Nuke ... compare to the extra 3000E the foundry ask i can have a PFTrack license @1400E which is far better imo ! my goal is just to be able to ditch nuke of my workflow and i'm prettry sure that COPS on steroid could do that ... the VEX tools in COPS are just stellar for exemple you don't have that in Nuke ... a solid 2D tracker to put COPS on the same level than shake 4.1 would be good enough imo ... Edited January 3, 2017 by sebkaine Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 4, 2017 Share Posted January 4, 2017 could be a good start - but we use also planar trackers now which probably is much better tech to start with in 2017. Quote Link to comment Share on other sites More sharing options...
malexander Posted January 4, 2017 Share Posted January 4, 2017 On 12/15/2016 at 9:24 AM, marty said: @KardonnThe "Set display options for 'Display Model Geometry'" under Display Option Markers could do with a clean-up. Not so intuitive currently. Expand What specifically do you find unintuitive about it? There's quite a bit of information there, I'm curious what you'd like to see. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 4, 2017 Share Posted January 4, 2017 (edited) On 1/4/2017 at 9:44 PM, malexander said: What specifically do you find unintuitive about it? There's quite a bit of information there, I'm curious what you'd like to see. Expand I probably just need to play more with it but I'm not sure of the interrelationship of the left menu with the right menu, and, how the checkboxes relate. Is it correct the 'Set display option for' menu is the setting you are using to choose the below checkboxes, but you can also use the 'Use' menu as an override? Edit: Testing shows these issues that add confusion, at least to me: There is no option for selected scene geometry when the Handle/translate/rotate/scale tools are selected. It would be better to behave like the Selected Scene Geometry setting The 'Set display options for' menu could be clearer what is Geometry level vs Scene level. A subheading would help. Overall the help page would be improved with pictures. Edit2: also add a line below 'Unique Settings', in the 'Use' menu to identify it separately from the other settings. There probably is a better way to lay it out overall but these types of changes would help. Thx! Edited January 5, 2017 by tar Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 5, 2017 Share Posted January 5, 2017 (edited) It would be really nice if cloud noise could do something like this: This person's solution works extremely well and is computationally inexpensive, but it's pretty substantial to set up from scratch. BTW - if anyone knows if this person is on OdForce, I'd like to get in touch with him/her as for some reason Vimeo's message service doesn't seem to work right for me at the moment. Edited January 5, 2017 by shawn_kearney Quote Link to comment Share on other sites More sharing options...
edward Posted January 5, 2017 Share Posted January 5, 2017 On 1/5/2017 at 3:49 AM, shawn_kearney said: BTW - if anyone knows if this person is on OdForce, I'd like to get in touch with him/her as for some reason Vimeo's message service doesn't seem to work right for me at the moment. Expand Did you try emailing him? There's contact info on his website: http://www.neonjunkyard.com/about/ 1 Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 5, 2017 Share Posted January 5, 2017 cool thanks! Quote Link to comment Share on other sites More sharing options...
fencer Posted January 9, 2017 Share Posted January 9, 2017 +-release date? 1 Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted January 9, 2017 Share Posted January 9, 2017 (edited) Should be soon - I downloaded an extension on Orbolt yesterday and was asked if I have Houdini 16 installed or want to download it. The link didn't work, but it looks as if the gears are already turning... :-) Edit: there is also this Tweet: Cheers, Tom Edited January 10, 2017 by Thomas Helzle 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 11, 2017 Share Posted January 11, 2017 like a sieve; H16 screenshots on Foundry community. Looks to be terrain stuff and viewport rulers **** they're on the Foundry Forum until I can get them taken down...but I can take these down. - goldfarb Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 11, 2017 Share Posted January 11, 2017 On 1/11/2017 at 9:45 PM, marty said: **** they're on the Foundry Forum until I can get them taken down...but I can take these down. - goldfarb Expand sigh - guess when SideFx adopts an open beta methodology censorship will be consigned to the dustbin.... Quote Link to comment Share on other sites More sharing options...
michael Posted January 11, 2017 Share Posted January 11, 2017 On 1/11/2017 at 10:35 PM, marty said: sigh - guess when SideFx adopts an open beta methodology censorship will be consigned to the dustbin.... Expand it isn't censorship if it's a closed Beta. All those who currently have access to H16 have made very specific agreements not to disclose any information about it publicly. The fact that SideFX offers daily builds of Houdini makes it, in effect, a constant open beta - and means that users can get bug fixes and new features sometimes within a day or two of reporting them. When a new version is being prepared for public release I don't think it's too much to ask to be given the courtesy of releasing it the way SideFX wants to. 1 Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 12, 2017 Share Posted January 12, 2017 @michael that's a bit silly - it's an AUP beta currently, not closed. It was closed, invite only, before December last year. Foundry are leading the way with this - all paying customers of Modo/Nuke have access to the latest beta - time to step it up SideFx. Quote Link to comment Share on other sites More sharing options...
