Logo - Trace with Extrude and PolyBevel (need other workflow?)
ParticleSkull
I think for such a simple logo, you may want to consider re-drawing it using the curve tool. Then the polybevel may work correctly. The trace is a nice option but in the end it always ends up stair stepping along curves.
For tracing logos I prefer bezier curves because the resulting curve goes through the points. With nurbs there is some kind of offset between the curve and the point. With the curve flowing through the point you can drop the points on the exact corners of the font or shape, in front or side view.
For best tracing results, set the viewport to an orthographic view before you begin drawing.
Edited by Atom
