How can I use "Turbulent Noise" as a displacement?
Hi;
I would like to use "Turbulent Noise" as a displacement texture in my material, but it doesn't works properly, why?
My goal is to achieving a displacement output like this link:
https://www.sidefx.com/forum/topic/45673/?page=1
Thanks for helping.
Displacement.hipFetching info...
Edited by Masoud
Aah, I just had a hard time dealing with this problem this weekend.
Found some solutions but overcomplicated IMO.
With just a principled shader at Mat level is so simple, by the way no need to unwrap or rest sop in the sphere object... but I can't get it to work in a material builder. trying all sort of tranform space but no way.
But thank to sreltak network I guess why. Need to retry.
Displace_F.hipFetching info...
PS don't forget to frequently stop and restart mantra (not only refresh) when you do your tests.
Edited by flcc
Expand
hello flcc,
when you collaps to material network you have to re-assign the material to the sphere. it's still looking for the principledshader. but the displacment bound on the properties-node seems not working right. I deleted the channel and set it to 10 and it worked.
Edited by primzahl
Ah, I completely misunderstood the original Masoud question, I thought the goal was to see the material displacement in the viewport. I have no idea why, sorry :)
But I am still interested if ist possible.
Edited by kiryha
@primzahl
I try what you say, but I get this. Trying to crank up the bound value don't change anything.
Maybe there's something I didn't understand.
@kiryha
Look at the Houdini VOPs // Illume Webinar with Jeff Wagner. In the exemple files, there is one called vops_grunge_up_diffuse.hip where there is a material with displace visible in the viewport. Why it's work and mine not, I really have no idea.
Displace_F2.hipFetching info...
Edited by flcc
Expand
Thank you, but I want to use displacement in material builder...
  On 10/15/2019 at 6:39 PM, flcc said:
@primzahl
Expand
hello, I added the properties node to your network and now the displacment works. Kai Stavginski form sidefx explains the workflow in one of his shader-tutorials, but I have forgotten in which one - I belive it is the costum shader ...
Displace_F2_v1.hipnc
  • Thanks 1
Ahh Thank you very much.
So in materialBuilder context the displacementBound of the principled Shader don't work and you must use a mantra propertie !
it's a bit sneaky IMO.
I could never have found it on my own. And yet I searched. This should be indicated in bold and red in the displacement section of the doc.
Thanks again :)
Edited by flcc
