Masoud
Why I can't transfer “P” attribute values, to second geometry?
Posted (edited)
Hello;
I wonder why I can't transfer “P” attribute values, to second geometry, by “Attribute Transfer” SOP..!?
Thanks for helping.
Att_Transfer.hip
Edited by Masoud
Share this post
Link to post
And in your example, as distance between original points and displaced point is much greater than neighbour points distance, you also need to use source and destination groups.
Share this post
Link to post
If you don't need any of the other functionality of the attribute transfer node, it would be faster to use a wrangle:
@P = @opinput1_P;
(line into input 0, edit into input 1)
  • Like 2
Share this post
Link to post
you CAN write the vex yourself every time if you want to, or if you feel lazy, just a Point SOP, preset Morph to 2nd input then you can have a controlled lerp amount.
  • Like 2
Share this post
Link to post
22 hours ago, dleonhardt said:
That is what the "Match P Attribute" checkbox is for.
I turned " Match P Attribute "on, but it doesn't work.
Share this post
Link to post
vector pos = point(1, "P", @ptnum);
float mix = ch("mix");
@P = lerp(@P, pos, mix);
  • Like 2
Share this post
Link to post
Even shorter version:
@P = lerp(@P, @opinput1_P, ch("mix"));
  • Like 2
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
