Masoud Posted December 27, 2022 Share Posted December 27, 2022 Hi guys, I'm looking for a (simple and fast) way to fix intersections between geometries. I found this video: But the problem is the result is not that satisfying. I would appreciate any ideas. Thanks for helping. Quote Link to comment Share on other sites More sharing options...
fencer Posted December 28, 2022 Share Posted December 28, 2022 Quote But the problem is the result is not that satisfying. This doesn't give us any information about you issue, show your "not satisfying" result, share setup or example... The setup from the video is working as expected, tested. 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 29, 2022 Share Posted December 29, 2022 Have Some points and pscale att on those use this after //get neighbour pts finding a arrary int nPts[] = nearpoints(geoself(), @P, chf("maxdist"), chi("maxpts")); pop(nPts, 0); i[]@nPts = nPts; i@id = @ptnum; matrix mArray[]; float targetD[]; foreach(int pt; nPts){ float nRadius = point(geoself(), "pscale", pt); vector nPos = point(geoself(), "P", pt); float myRadius = @pscale; vector myPos = @P; float distance = distance(nPos,myPos); float collideLength = nRadius + myRadius; if ( distance < collideLength){ //intersectNums += 1; //set localMatrix[] by nearPoints vector z = normalize(nPos - myPos); vector x = normalize( cross(set(0,1,0), z)); vector y = cross(z, x); matrix m = set(x,y,z, myPos); m.xw = 0.0; m.yw = 0.0; m.zw = 0.0; append(mArray, m); //calculate intersect distance float intersectD = (pow(myRadius, 2) - pow(nRadius, 2) + pow(distance, 2)) / (2.0 * distance); append(targetD, intersectD); } } 4[]@mArray = mArray; f[]@targetD = targetD; then copy to points and than use this //foreach neighbour pts and check if the point sphere intersect with another guy int nPts[] = i[]@nPts; float targetD[] = point(1, "targetD", i@id); matrix mArray[] = point(1, "mArray", i@id); //set deform weight float weight = 0; foreach(int i; int pt; nPts){ //calculate intersect distance float intersectD = targetD[i]; //check if the Pt Pos > myRadius matrix m = mArray[i]; vector newPos = @P * invert(m); if( newPos.z > intersectD){ vector pos = newPos; pos = set(pos.x, pos.y, intersectD); @P = pos * m; weight = 1; } //weight = fit(newPos.z, -f@pscale, intersectD + chf("weight_offset"), 0, 1); } //f@weight = weight; f@weight = chramp("weight_ramp", weight); then blur weight Play with Code and Setup... Quote Link to comment Share on other sites More sharing options...
hannes603 Posted January 5 Share Posted January 5 @Librarian he sad , something simple XD love it Quote Link to comment Share on other sites More sharing options...
tamagochy Posted January 5 Share Posted January 5 On 12/29/2022 at 8:30 AM, Librarian said: Have Some points and pscale att on those use this after //get neighbour pts finding a arrary int nPts[] = nearpoints(geoself(), @P, chf("maxdist"), chi("maxpts")); pop(nPts, 0); i[]@nPts = nPts; i@id = @ptnum; matrix mArray[]; float targetD[]; foreach(int pt; nPts){ float nRadius = point(geoself(), "pscale", pt); vector nPos = point(geoself(), "P", pt); float myRadius = @pscale; vector myPos = @P; float distance = distance(nPos,myPos); float collideLength = nRadius + myRadius; if ( distance < collideLength){ //intersectNums += 1; //set localMatrix[] by nearPoints vector z = normalize(nPos - myPos); vector x = normalize( cross(set(0,1,0), z)); vector y = cross(z, x); matrix m = set(x,y,z, myPos); m.xw = 0.0; m.yw = 0.0; m.zw = 0.0; append(mArray, m); //calculate intersect distance float intersectD = (pow(myRadius, 2) - pow(nRadius, 2) + pow(distance, 2)) / (2.0 * distance); append(targetD, intersectD); } } 4[]@mArray = mArray; f[]@targetD = targetD; then copy to points and than use this //foreach neighbour pts and check if the point sphere intersect with another guy int nPts[] = i[]@nPts; float targetD[] = point(1, "targetD", i@id); matrix mArray[] = point(1, "mArray", i@id); //set deform weight float weight = 0; foreach(int i; int pt; nPts){ //calculate intersect distance float intersectD = targetD[i]; //check if the Pt Pos > myRadius matrix m = mArray[i]; vector newPos = @P * invert(m); if( newPos.z > intersectD){ vector pos = newPos; pos = set(pos.x, pos.y, intersectD); @P = pos * m; weight = 1; } //weight = fit(newPos.z, -f@pscale, intersectD + chf("weight_offset"), 0, 1); } //f@weight = weight; f@weight = chramp("weight_ramp", weight); then blur weight Play with Code and Setup... Can you post scene. This code doesnt work for me. Thanks Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 6 Share Posted January 6 @tamagochy Quote Link to comment Share on other sites More sharing options...
hannes603 Posted January 6 Share Posted January 6 it does work quiet greatly! keep it up! intersection_fix_geo_wrangle.hip Quote Link to comment Share on other sites More sharing options...
