New forum skin
Marc
hi!
I usually read the forums trough google reader via feed, the new feed link is there but in google reader i can only see the topics name, no content at all, so i have to go to see every topic one by one. Ok, YOu can say go read the forum directly, but for it is much more faster to use the reader.
Can You change something about the feed please ?
  On 7/20/2009 at 2:30 PM, Marc said:
Hey there
So let us know what you think of everything. This is quite a drastic change, so I expect there to be some comments :) . Please let us know of any bugs or major issues you have. Otherwise, comments/crits and the like are welcome here.
Cheers
od[force] chaps.
I simply love it! Really. I find it very clear and readable. I've opened in for a first time on 13'' laptop and I had no problems with readability (perhaps too dark icons for forum subtopics?). I had a bigger problem to get used to during last time of change ;)
Thank you guys!
does the search function work properly or am i completely missing something.. trying to search multiple terms and not having much luck. for instance, i wanted to find out what happened to the shadow style parm for deep shads back in H8 (doesn't seem to be available in H10 even though it's mentioned in the docs)..
So I tried searching "+shadow +style" and it only returns results for "shadow".. "shadow style" also does not seem to work..
any thoughts?
edit:
well ""shadow style"" seams to work.. but what if you wanted both words without being consecutive as in a sentence? ""shadow" "style"" spits back threads with either words, not both.
edit #2:
i also found what i was looking for regarding shadow styles over on the sesi forums:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=10450&highlight=shadow+style
Edited by deecue
It's looking great to me! I just have a small request if it's not too hard to do: I also read the forum through a rss feed, would it be possible to have the sender be the post/reply author (and not odforce) and the date reflect the post/reply actual sent date (not the thread original post date)? The behavior I'm suggesting was the default before, which worked really well imho (long threads become not so easy to parse with the current system).
Sorry if this is already available, I might be missing some nifty options :)
Thanks,
O.
  On 7/27/2009 at 8:28 PM, olivier said:
Thanks,
O.
I'll take a look but I suspect the rss feeds really are that bad. We don't have too many option unfortunately. The previous version of the forum had been patched to make the rss feeds better, but that's not the case anymore. As soon as I have a spare moment I'll have to dig through their feed code to see what's up and try and sort it out.
So, sorry about this but I'll do what I can to fix it.
M
After the skin update, I can't see odForce forum on iPhone any more...
Trying to open forums.odforce.net with the iPhone browser gives this:
Fatal error: Call to undefined method skin_global_3::forum_jump() in /home/odforce/public_html/forums/admin/applications/forums/sources/classes/forums/class_forums.php on line 1462
M
Thanks Marc :)
