FLIP smorganic/sheeter effect?
poppy
  • 4 weeks later...
Hey Folks!
I read this thread with great interest and I am amazed of all your creativity and technical raffinesse! I was wondering... how's the state of all this? I am currently fighting with a small scale fluid sim and coud really use this new and awesome technique! Any updates?
I was trying to make a dirty / cheap tricks to achieve this kind of stuff , but my R&D skills sucks deeply !
I wanted to generate a mesh with point proximity from the lowrez flip , i give a try to delaunay because it was the only one that come to my mind ...
I would be curious to get your pov on a method that would allow to generate a polymesh that would be a sort of Mix beetween
- delaunay tessalation for closest point connection
- convex hull for getting a sheets
Your tricks is perfect and will do the job wonderfully , but i have the feeling that a fast B-plan could be possible.
- for exemple you select a starting position
- then from this position you build triangulation with closest point
- you do this until there is no more point and you check that you keep sheets pattern ...
the idea is then to
- smooth the mesh
- add some nice displace on it
- then scatter point on it that stuck
- mesh in VDB
Do you have any math stuff in your magic box that could do something like that ?
Does it look doable ? / Clever ? / Stupid ? to You !
Thanks again for your Magic !
Cheers
E
Edited by sebkaine
After some googling a find those stuff that kind illustrate the idea
http://pointclouds.org/documentation/tutorials/greedy_projection.php
http://www.cs.unc.edu/~isenburg/sd/
http://www.cs.cmu.edu/~quake/triangle.html
it doesn't look as easy as i might expect ... basically it's surface reconstruction from a point cloud
- by checking that we keep sheet pattern => no volume
- by checking that mesh curvature keep a smooth pattern
i find this method on wikipedia to build mesh from ptc
http://en.wikipedia.org/wiki/Delaunay_triangulation
http://en.wikipedia.org/wiki/Alpha_shape
http://en.wikipedia.org/wiki/Voxel
http://en.wikipedia.org/wiki/Distance_transform
http://en.wikipedia.org/wiki/Implicit_function
http://en.wikipedia.org/wiki/Marching_cubes
i'll try to invstigate this if i have enough time !
this might be interesting also !
http://meshlab.sourceforge.net/
  • 3 weeks later...
Hello!
As I already mentioned I don't have any free time to spend on this, so you should try to convert it yourself. Sorry about that!
Emmanuel ideas sounds great - unfortunately right now I can't help with that either :/ I'll be glad to see if you can make any progress as it looks like a really promising project!
Cheers!
Thanks for feedback Pavel ! i'm actually trying to see if it's possible to use low rez FLIP sim to drive a Cloth Object . which would be a poor implementation of what i have in mind.
But i think that to get water sims that look like thin sheets, using a sheets could be a good idea when you don't want to go the hard way with surface tension / point replication etc ...
those mesh reconstruction stuff from ptc are a little to much on the dev side for my brain ... :)
Thanks for fast reply Pavel!
i am close to finishing a project, so after i will try to  understand your technique in deep and use it with SPH for sure! I need some free time for do it too.
Anyway, i found a strange behaviour in houdini when i put VEX code on a env path to run  your scene, some times the node "points from volume" not work anymore, in all scenes! If i remove from the path, the node works again. (but this appear interstitial)
Have you any idea what can be wrong? (looks like vex code is overriding some function inside node, is it possible?)
Thanks again man, incredible work.
Edited by rod.vfx.td
when you set your VEX path , you overide the houdini default VEX path , so houdini will not work correctly.
you have to put the & symbol like this to concatenate your new path with the default path:
HOUDINI_VEX_PATH = <my_custom_path>;&
Oh, it is so obvious, my mistake...
Thanks Emmanuel.
  • 9 months later...
