Mzigaib Posted September 20, 2013 Share Posted September 20, 2013 It seems simple but I couldn't figure out how to procedurally create a cubic UV map fora a simple 6 sides cube, Any tips? Thanks. Quote Link to comment Share on other sites More sharing options...
edward Posted September 21, 2013 Share Posted September 21, 2013 Not sure what you mean. Have you tried the UVUnwrap SOP? Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted September 22, 2013 Author Share Posted September 22, 2013 Thanks for the feedback. Is about the way the uvs are layed, it needs to be layed follow a cubic vertical environment cube. UV unwrap works for texturing but it doesn´t position the uv´s right away with the cross cubic env image you have to do it by hand. Does it make sense? Quote Link to comment Share on other sites More sharing options...
acey195 Posted September 22, 2013 Share Posted September 22, 2013 You can do this by doing 6 separate projections (UV texture or UV project) for each side to the cube and move them in position. If you simply do that upfront, you can afterwards change the cube and the UVs should remain intact. You could even morph this cube in a quad sphere if that is what you are looking for. Shameless self plug is shameless: http://www.twandegraaf.nl/Art/Documents/Procedural%20planets%20into%20detail,%20Twan%20de%20Graaf%202012.pdf see page 6. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post konstantin magnus Posted April 10, 2017 Popular Post Share Posted April 10, 2017 (edited) Here is a vertexwrangle method for projecting cubic UVs on any kind of mesh: vector bbox = relbbox(0, @P); vector side = sign(@N); vector nml = abs(@N); vector size = getbbox_size(0); vector ratio = size / max(size); vector scale = bbox * ratio; if (nml.x == max(nml)) { @uv = set(scale.y * side.x, scale.z, 0); } else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, scale.z, 0); @uv.y += 1; } else { @uv = set(scale.x * side.z, scale.y, 0); @uv.y += 2; } @uv *= 0.3333; @uv.x += 0.5; Edited April 10, 2017 by konstantin magnus 11 3 Quote Link to comment Share on other sites More sharing options...
broomy Posted April 27, 2017 Share Posted April 27, 2017 I tried a similar thing a while back, its a fair amount of script to position the uv projections on each side of the box Hope it helps Quote Link to comment Share on other sites More sharing options...
Atom Posted April 27, 2017 Share Posted April 27, 2017 (edited) Thanks Konstantin, it seems to work well for spaceship parts. Now I can finally paint my ships in Mari! Edited April 27, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted April 27, 2017 Share Posted April 27, 2017 20 minutes ago, Atom said: Thanks Konstantin, it seems to work well for spaceship parts. Hehe cool, makes me proud to see it´s of any use! Quote Link to comment Share on other sites More sharing options...
jeannel Posted November 27, 2017 Share Posted November 27, 2017 Loved that one, very usefull, thank you ! Quote Link to comment Share on other sites More sharing options...
Richard Costin Posted April 2, 2019 Share Posted April 2, 2019 Very useful, many thanks konstantin magnus Cheers, Rich. Quote Link to comment Share on other sites More sharing options...
Hepamine Posted November 18, 2019 Share Posted November 18, 2019 (edited) Thanks a lot Konstantin Magnus! Edited November 18, 2019 by Hepamine Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 18, 2019 Share Posted November 18, 2019 On 4/27/2017 at 11:50 PM, konstantin magnus said: Hehe cool, makes me proud to see it´s of any use! I'm not proud !!! I'm reading your code over and over and still got NFI !!! Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted November 19, 2019 Share Posted November 19, 2019 (edited) Ok, it's been a while, but let's try it one by one: 1. Scaling world coordinates to unit size vector bbox = relbbox(0, @P); vector size = getbbox_size(0); vector ratio = size / max(size); vector scale = bbox * ratio; relbbox() creates linear gradients along each axis of the object from 0.0 to 1.0. Those can be spread out in UV space later. getbbox_size() returns the absolute dimensions of the object. While we don't care about the actual size, we need to factor in how those dimensions relate to one another: size / max(size) Dividing all dimensions by the biggest one effectively scales them to unit size while keeping the proportions. This is the aspect ratio for X, Y and Z. bbox * ratio combines the gradients on all mesh points with the overall aspect ratio. All projections fit proportionally onto the UV grid now, we only need to split them up and lay them out. 2. Splitting up projection sides vector side = sign(v@N); vector nml = abs(v@N); if (nml.x == max(nml)) { ... } else if (nml.y == max(nml)) { ... } else { ... } sign(v@N) decides towards which side the normals point to. Its either left or right, top or bottom, front or back. Later this will compensate for.. abs(v@N) setting all normals to positive values. So we can easily compare which direction they are mainly facing, using: if (nml.x == max(nml)) for X, else if (nml.y == max(nml)) for Y and else for Z. By comparing each absolute component with the normals' maximum, we split the geometry into UV islands. 3. Laying out UV coordinates if (nml.x == max(nml)) { @uv = set(scale.y * side.x, scale.z, 0); } else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, scale.z, 0); @uv.y += 1; } else { @uv = set(scale.x * side.z, scale.y, 0); @uv.y += 2; } @uv *= 0.3333; @uv.x += 0.5; set(scale.x * side.y, scale.z, 0); Depending on which side has won, the UV coordinates are composed of either top or side views (first component) and front or side views (second component). Setting the scale variables negative can be used to sort out direction issues. *side.x, *side.y and *side.z are simply flipping directions in case the normal directions have been negative. Thus getting their own islands on the left side. @uv.y += 1; and @uv.y += 2; are moving the UV islands upwards, so they are not landing on top of each other. @uv *= 0.3333; Currently UV coordinates span across six unit spaces, so we scale them down to fit into one. @uv.x += 0.5; Because of flipping the sides we also have to move all our coordinates to the right by half. Alright, I hope things got less confusing now. Edited November 19, 2019 by konstantin magnus 5 1 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted November 19, 2019 Share Posted November 19, 2019 I'd like to bookmark posts, is that not possible ? Quote Link to comment Share on other sites More sharing options...
dandandan Posted September 4, 2020 Share Posted September 4, 2020 On 10/4/2017 at 2:06 AM, konstantin magnus said: Here is a vertexwrangle method for projecting cubic UVs on any kind of mesh: vector bbox = relbbox(0, @P); vector side = sign(@N); vector nml = abs(@N); vector size = getbbox_size(0); vector ratio = size / max(size); vector scale = bbox * ratio; if (nml.x == max(nml)) { @uv = set(scale.y * side.x, scale.z, 0); } else if (nml.y == max(nml)) { @uv = set(scale.x * side.y, scale.z, 0); @uv.y += 1; } else { @uv = set(scale.x * side.z, scale.y, 0); @uv.y += 2; } @uv *= 0.3333; @uv.x += 0.5; Thanks Konstantin, that's amazing! For those who get some weird stretched uv, I solved by deleting any Normal attribute before feeding geo into vertex wrangler. Very basic but it took me a while to figure it out.. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 27, 2022 Share Posted March 27, 2022 On 19.11.2019 at 3:21 AM, CinnamonMetal said: I'd like to bookmark posts, is that not possible ? I have just published the same article on my procedural generation page: https://procegen.konstantinmagnus.de/cubic-uv-projection-in-vex 3 1 Quote Link to comment Share on other sites More sharing options...
Drughi Posted March 31, 2022 Share Posted March 31, 2022 (edited) Always cool to have stuff in vex! I just wanted to mention, that this is also implemented natively with the uvunwrap node. Edit: Was just reading about the cubic vertical environment cube uv layout thing. Missed that one. Edited March 31, 2022 by Drughi Quote Link to comment Share on other sites More sharing options...
