16.5 drums
kev2
SideFX has a cycle for their major releases, so you'll probably hear something again sooner than later.
They have launched in the past at Siggraph, a few rare Halloween treats, and then a few winter/spring drops. I'm actually surprised I couldn't find a Wikipedia like entry for their past release dates. Unlike Autodesk they don't launch until they have something worth upgrading about so the timings are not standardized. There is normally an Alpha and Beta build that go up before final launch so they can iron out the major kinks before launch. It's against the NDA to talk about the next major version publicly. Occasionally you'll see a few folks post that don't understand this. Usually a major version is active from say 9 months to 18 months. H14 was the shortest life cycle I can think of, but 16 was only launched this past winter, so it will be all in good time. Only when it goes past a year do people start to hit the drums.
  • 3 weeks later...
Good stuff!
"Quick marks are now saved with the scene file."  Hallelujah :-) I may even use them now...
No changes to the code editor though it seems... :-(
Well, there's always Houdini 17 to hope for a decent editor...
Still the Nr. 1 feature I'm missing each and every minute I use Houdini...
Funny how devs can be blind to something they use probably 24/7...
Cheers,
Tom
Anyone else experience a lag after pressing 'S' in transient mode? A delay between the moment of key pressing and the tool activation. The same with 'space' key. 'alt' seems to be unaffected.
Another gremlin seems to be playing with an edge selection persistence after click-drag on empty space to deselect.
Can anyone confirm?
edit: regarding "edge selection persistence", I've restarted H and the problem disappeared. Hopefully for good.
Edited by McNistor
Cheers,
Tom
They code in "opcode" or maybe they know all commands or maybe they dont even need eyes for codeing.... pssst they are ninja coders :ph34r:
About S lag : I notice your lag but it just affect the display of the tool activation because in use it seems pretty reactive, as well as "alt" (just test in a really simple scene).
9 minutes ago, McNistor said:
@julca indeed, the lag is only a display issue
There seems to be no problem with pressing '1' for going back to object mode here.
Ok, I'm jalous or perhaps I've made a mistake..
On a new scene I create a cube, move some points and now if I hit 1 it doesn't do anything.. (It will normaly go in object mode)
cf. screenshot
