So somebody else posted on the thread, seems it's only me who can't post on my own thread... Weird. - Today
@caskalDid you ever figure this effect out? I'm super curious how you got the effect you were getting in your attempts.
- 6 replies
- heightfield
- painting
Emit 1 Particle Per Sec - Starting From Frame 1
Thanks @Atom! Making great progress! I've also created a 'firing' toggle with your previous vex wrapped in another if statement (if firing == 1, shoot bullets, else remove all points). int fire = chi("firing"); if(fire==1){ if(@Frame!=1){ if ($FF % chf("shoot_every_frames")){ removepoint(0,@ptnum); } } } else{ removepoint(0,@ptnum); } I think I now need to know which frame that fire toggle has been activated? My thoughts are to replace: '@Frame!=1` With: '@Frame!=@fire_activation_frame' I just need to work out how to store that '@fire_activation_frame' attribute when the fire toggle is first set to 1. Any ideas? emit_particles_v03.hipnc -
I'm trying to create something like this. I'm drawing a blank? Two grids rotating, but they need to loop. Would this just be an animated twist node?
