OnurBurak started following Behaviors for Crowd
Hello, I want to create a crowd simulation in Houdini, but I don't know how to do it. What I want is for the crowd to interact with each other, form queues or lines, and create stop-and-go waves, just like in Golaem. I tried using Crowdtrigger-Particle Proximity, but it didn't work properly. Any suggestions or advice would be a lifesaver. Thank you.
RobertCampanelli joined the community
pierre897557 joined the community
soft selection tool in houdinis animation graph
@hannes603 Find Rok Andic he makes that finny cartoons , juts send email to Dude .. You gonna get Help. -
houdini can do so complex and different things in so manny different ways no other software is capable of. and than such an easy simple tool like that is just not available. -
hyeju joined the community
migfuege joined the community
Sepu replied to hannes603's topic in General Houdini Questions
Not quite the same, the only thing that you have that is somewhat similar is the box handle but as far as I know you can not change the division. So it will work similar to what he is showing around 1:20 -
wow no one ? so i suppose its just not possible right - Last week
Hi am trying to execute the erosion sim inside a top network but had no success, I tries to use a python line to achieve the task but it works eventually but not all the time, I believe am doing it wrong can someone guide me for the right method thanks
zanmaer joined the community
does anyone know how to achieve this type of noise/ effect?? i think it's the particles advected by a simulated pyro sim. check the attached video. thanks Snapinsta.app_video_8648930361E516ACDF2BF88BE1AC618D_video_dashinit.mp4
I'm really not having an easy time adapting to Solaris...so you might need to explain like I'm five. I have a RedshiftRendeSettings node that sets up all the usual AOVs, It's writing multiple frames, it's fine. Above that node I have a renderVars node that sets up the cryptomatte. I tested a bunch of single frames and only when I submitted the big render did I realise that it's only writing one frame of that seperate AOV output. This is the output path on that renderVars node (the @EYE strings are custom pipeline wrangles): q:/`@EYE_g0_name`/Build/`@EYE_g1_name`/`@EYE_g2_name`/`@EYE_g3_name`/render/3d/`@EYE_element_type`-`@EYE_element_name`_v`padzero(3,@renderversion)`/`@passname`/CRYPTO.$F4.exr it looks like it's continually overwriting this frame: CRYPTO.0250.cryptomatte.exr 250 is the end of the frame range in the USD ROP As I step through the range in solaris, the output path in the scene graph reads correctly for the renderVars and the current frame...so it might be globally overwriting that path as it runs through the time-range for every frame of the USD write. Greatful of any help!
Thanks for your help, it’s working fine!
- 2 replies
- particles
- velocity field
I have reworked Alejandro's fill a flip collider from an exterior source. This re-work of the network uses the newer H20 nodes. NOTE: If you get a font error, just pick one that is on your system. Original HIP files found here: ap_pazuzu_FLIP_fill_FONT_from_outside_050824.hiplc
@numpt vs npoints (VEX vs Hscript)
Mike_A replied to r-a-n-d-o-m's topic in General Houdini Questions
Its May 2024... and I was looking for some clarity on this matter. I really appreciate the info in this thread, but I think I may need a paracetamol... : ) -
hey gabriel! I'm facing the same issue. did you find a way to fix it?
pop advect volumes allow you to grab the velocity from your volume to move your pts.
- 2 replies
- particles
- velocity field
Hello, i have created a sim with a big explosion inside a tall building and i also have a rain simulation outside, i was wondering how i can transfer the velocity from the pyro into the popnet in order to make the rain react with the "blast" of the explosion when it first starts, thank you!
- 2 replies
- particles
- velocity field
Turns out $F should have been ${F}
thanks guys. this helped me. My issue was that the collider just wasnt moving. I guess the shelf tools sometimes really can help to figure out stuff. I didnt know that i had to put a static solver in the dop net and my static object node was not set up correctly.
- 7 replies
- static object
- container
(and 3 more)
- 2 replies
- lop import
- instance node
- 2 replies
- lop import
- instance node
