tarelkiin joined the community
F_E_X joined the community
Tugh joined the community
rajnlove joined the community
Thanks @Librarian although this example is working post popnet, the number of points is static. The issue still exists of this working on a changing point count sim (post sim, not inside the popnet). That has been the most difficult part of this process that has me stumped.
- fire
- karma rendering
Great, this hip helped me
- popnetwork
- spin
Are you interested in creating custom velocity fields and custom forces for your Houdini FLIP, Pyro and Smoke Simulations?? Are you interested in building custom DOP networks and custom solvers? This course on Udemy is for you! Enroll it now from HERE! https://www.udemy.com/course/mastering-houdini-simulation-custom-forces-velocity-fields/?referralCode=374420356510272B5A71 Course Overview: Take your Houdini simulations to the next level by mastering the art of custom velocity fields and forces. This advanced course is designed for artists and technical directors looking to gain full control over their simulations. Through real-world examples, we will explore a variety of techniques to create stunning motion effects using velocity volumes, custom forces, volume VOPs, and point clouds. By the end of this course, you will have the ability to craft complex, Houdini dynamic simulations that behave exactly as you envision. Whether you're working with particles, smoke, FLIP water simulations or other volumetric effects, these techniques will help you stand out in the world of VFX and motion design. What You’ll Learn: How to create custom velocity fields for unique water, particle and smoke effects Techniques for designing an ocean vortex with beautiful banding effect Crafting custom curve forces to guide particle and smoke simulations Utilizing complex geometry to generate unique force interactions Creating a particles-to-word effect using object forces Developing axis-related forces for controlled simulations Applying velocity volumes in various ways, including: POP Advect by Volume Wind forces Directional drag and full drag Advanced techniques with Point Clouds and Volume VOPs for precision control Create a curve force and axis force digital assets that can be used to control smoke and particle simulations Course Breakdown: Module 1: Ocean Vortex Effect Designing a realistic vortex simulation Using velocity banding for artistic control Fine-tuning the look of fluid motion Module 2: Curve-Driven Forces for Smoke & Particles Creating custom curve forces Directing smoke and particles along a path Controlling force strength and falloff Leveraging Point Clouds for volume manipulation Customizing Volume VOP networks for precise effects Debugging and optimizing simulations Module 3: Forces & Complex Geometry Using geometry to influence simulations Crafting intricate force interactions Case study: Real-world examples of geometric forces Module 4: Particles to Word Effect Transforming particles into text shapes Managing object forces for controlled transitions Enhancing readability and motion flow Module 5: Axis-Based Forces for Dynamic Simulations Applying forces relative to an axis Rotational and directional force applications Controlling turbulence and flow behavior Understanding POP Advect by Volume Blending velocity for natural movement Wind, directional drag, and full drag techniques Who This Course is For: Intermediate to advanced Houdini users VFX artists looking to master simulation control Motion designers who want more precision in particle and smoke effects Technical artists eager to dive into advanced Houdini workflows Why Take This Course? Learn industry-standard techniques used in professional VFX studios Gain hands-on experience with practical, project-based lessons Unlock the ability to create your own unique simulations Elevate your skills and portfolio with high-end effects using Houdini Course Requirements: Basic knowledge of Houdini A computer capable of running Houdini simulations Passion for creating stunning, controlled simulations Are you ready to take full control of your simulations? Enroll now and start mastering custom velocity fields and forces today!
- Earlier
Hello, I'm moving from US to Europe and I'm trying to figure out the best way to ship a workstation overseas. So far the idea is to buy a flight case and add some expandable foam on the sides. I don't want to open the workstation to take any parts since I don't have too much experience and this was built custom, it was originally sent from EU to US and it was fine, so hoping continues that way now that I need to ship back. Any thoughts regarding: 1) Best methods to ship 2) Specifics on the flight case 3) Any companies (Fedex, UPS, DHL) Would be super helpful. Thanks!
Would love to see that working please @hannes603 Your example file looks incomplete? The infection spread does not work unfortunately. @Librarian That infection solver looks amazing, but unfortunately I'm unable to install any otls at the studio I'm working.
infection on changing point count is usually no problem . it should work directly like here right untitled.mp4 pop_infection_on_changing_point_count.hiplc
https://github.com/linkanr/Infection
Thanks @Librarian @konstantin magnus @hannes603 all really great examples! Just to throw a spanner in the works, one pretty major issue I forgot to mention was the points I'm working with are disconnected and animated.. I managed to get @hannes603 example working on an animated static point count object by swapping the inputs of the vop inside the solver: But unfortunately this does not work when I have a changing point count when working with particles - I tried copying the attribute from previous frame onto the current frame using point ID to match attributes, but the entire object is filled almost instantly with the infected attribute. Any ideas when working with animated changing point count objects? Updated file attached: attribute_spread_v2_animated.hiplc
