Mahesh_Dubey joined the community
10yac joined the community
Sarah Brauneis joined the community
lsqlhbox joined the community
- lop
- instance node
Copy to points after rbd sim
Exactly like this thanks!
- 2 replies
- carve
You could convert those boats as vdb to be use as a colliders. I highly recommend to do some prep work before to them such as convert that geo as convex hull in a static frame, then using point deform to get them back in place. other than that the geo can be use as colliders individually inside dops, or merge them in sops. -
CarlosGuzman started following Intrinsic transforms, matrices and volumes
Yes, this is working... Ok, why it does not work if I set the position in the same wrangle where I define attributes? snippet_move_points_same_aw.hiplc
