guonan100 joined the community
GlennimusPrime started following Pop Advect By Volume Problems
With Pop Advect By Volume inside a POPnet, when particles reach the edge of the volume / the volume bounds, they lose all velocity and just stop. I recall seeing a video somewhere of someone who builds a better Pop Advect By Volume node, by diving inside and setting the particle velocity to continue, rather than just hitting zero. Does anyone know the video I'm talking about? I cannot find it anywhere. Or does anyone have any ideas on how to implement this technique?
adamknauer1 replied to adamknauer1's topic in General Houdini Questions
@Shieh3YES! That's the tutorial. Thank you so much -
Siyun joined the community
Data_Man joined the community
arevcuk joined the community
Nurbek joined the community
pip joined the community
megm joined the community
Thank you That exactly what am was looking for -
Chatbot??
- pipeline
- automation
(and 3 more)
