Attribute Growth [SOLVED]
Markus16yo joined the community
elwnn joined the community
Hi there, I'm trying to bake vertex colors applied to a high-res mesh into the same mesh but low-res and both have a principled shader applied to it. For now, no matter what I change in the principled shader or in the bake texture rop, the baked image comes out black. White UV island img attached If I just try baking a simple texture based on the high-res uv space, without transferring to the low-res mesh, a shiny white UV island image is created. I checked "Use Point Color' in the principles shader, applied the shader to the mesh, in the "bake texture" rop, I add the UV object, and check the Surface Unlit Base Color (basecolor) and the image is baked white. How can vertex colors can be properly baked in Houdini? - Last week
atomcc joined the community
doduyanh joined the community
zunaira123 joined the community
eikoh joined the community
Amazing, that's it! Thanks so much @hannes603 Really appreciate all the effort both you and @Librarian have gone through here to tackle this one. Goes to show the greatness of the Houdini community. Many thanks. - Earlier
- fire
- karma rendering
Great, this hip helped me
- popnetwork
- spin
Are you interested in creating custom velocity fields and custom forces for your Houdini FLIP, Pyro and Smoke Simulations?? Are you interested in building custom DOP networks and custom solvers? This course on Udemy is for you! Enroll it now from HERE! https://www.udemy.com/course/mastering-houdini-simulation-custom-forces-velocity-fields/?referralCode=374420356510272B5A71 Course Overview: Take your Houdini simulations to the next level by mastering the art of custom velocity fields and forces. This advanced course is designed for artists and technical directors looking to gain full control over their simulations. Through real-world examples, we will explore a variety of techniques to create stunning motion effects using velocity volumes, custom forces, volume VOPs, and point clouds. By the end of this course, you will have the ability to craft complex, Houdini dynamic simulations that behave exactly as you envision. Whether you're working with particles, smoke, FLIP water simulations or other volumetric effects, these techniques will help you stand out in the world of VFX and motion design. What You’ll Learn: How to create custom velocity fields for unique water, particle and smoke effects Techniques for designing an ocean vortex with beautiful banding effect Crafting custom curve forces to guide particle and smoke simulations Utilizing complex geometry to generate unique force interactions Creating a particles-to-word effect using object forces Developing axis-related forces for controlled simulations Applying velocity volumes in various ways, including: POP Advect by Volume Wind forces Directional drag and full drag Advanced techniques with Point Clouds and Volume VOPs for precision control Create a curve force and axis force digital assets that can be used to control smoke and particle simulations Course Breakdown: Module 1: Ocean Vortex Effect Designing a realistic vortex simulation Using velocity banding for artistic control Fine-tuning the look of fluid motion Module 2: Curve-Driven Forces for Smoke & Particles Creating custom curve forces Directing smoke and particles along a path Controlling force strength and falloff Leveraging Point Clouds for volume manipulation Customizing Volume VOP networks for precise effects Debugging and optimizing simulations Module 3: Forces & Complex Geometry Using geometry to influence simulations Crafting intricate force interactions Case study: Real-world examples of geometric forces Module 4: Particles to Word Effect Transforming particles into text shapes Managing object forces for controlled transitions Enhancing readability and motion flow Module 5: Axis-Based Forces for Dynamic Simulations Applying forces relative to an axis Rotational and directional force applications Controlling turbulence and flow behavior Understanding POP Advect by Volume Blending velocity for natural movement Wind, directional drag, and full drag techniques Who This Course is For: Intermediate to advanced Houdini users VFX artists looking to master simulation control Motion designers who want more precision in particle and smoke effects Technical artists eager to dive into advanced Houdini workflows Why Take This Course? Learn industry-standard techniques used in professional VFX studios Gain hands-on experience with practical, project-based lessons Unlock the ability to create your own unique simulations Elevate your skills and portfolio with high-end effects using Houdini Course Requirements: Basic knowledge of Houdini A computer capable of running Houdini simulations Passion for creating stunning, controlled simulations Are you ready to take full control of your simulations? Enroll now and start mastering custom velocity fields and forces today!
