Silly Challenge no. 2
anakin78z
Alrighty, here's another challenge. It may look simple at first, but I found it kinda fun to do.
Check out this animated gif, and reproduce the system.
Guidelines:
1. The orange arm always stays the same length.
2. The light green connection can only move up and down.
3. The cylinder in the middle only rotates, and doesn't move.
Ok, I think that covers it.
Let's see how long it takes ya ;)
  • 2 weeks later...
  • 6 months later...
  • 2 weeks later...
I'm relatively new to houdini. Can you guys post your hip files or at least give a description of how you did it. That would be greatly appreciated. There are certain things I'm getting through but it would be optimal to have one control drive the rig completely.
Thanks a whole lot :blink:
  • 1 month later...
hey halion.. i think you got some issues going on with your solution.. you're damn close, just one little mistake to fix and you got it...
of course i'm not gonna tell you what that is.. thats part of the challenge :D
just closely look at the other results and then yours and pick apart what it might be.
thanks for sharing
dave
wow.. thats some involved stuff you guys.. impressive :D
here's my solution and image.. all expressions.
HIP File
halion: to point you in the right direction, think about "slipping" and how these things should be "locked" to eachother in some sort of sense... hope that helps and maybe these few last posted solutions will help as well.. let us know if you need some more pointers...
