Masoud Posted February 21, 2022 Share Posted February 21, 2022 Hi guys, How can I convert a point cloud to a surface? Thanks for helping. PointCloud_To_Surface.hip Quote Link to comment Share on other sites More sharing options...
sebkaine Posted February 21, 2022 Share Posted February 21, 2022 (edited) i don't think that you have a default tool for surface reconstruction from a point cloud. If you really need accurate result you need to check Poisson surface reconstruction algorithm. https://hhoppe.com/poissonrecon.pdf Implementing this in vex might be hard and slow there is a thread that talk about this : I would find a good binary executable that do poisson surface reconstruction, and that can be call with a command line , then link it to houdini by taking exemple of what they do in the Labs Instant Meshes nodes. https://www.cs.jhu.edu/~misha/Code/PoissonRecon/Version13.72/#EXECUTABLES there is also a Labs AliceVision Meshing nodes , that might be interesting to check before , cause it might be able to already do this. i have never try it. Edited February 21, 2022 by sebkaine Quote Link to comment Share on other sites More sharing options...
Atom Posted February 21, 2022 Share Posted February 21, 2022 Try VDB from particles and convert that to polygons. Quote Link to comment Share on other sites More sharing options...
Masoud Posted February 21, 2022 Author Share Posted February 21, 2022 Hi Atom, VDB is not a suitable workflow, because it makes an unwanted offset on the surface and is slow to convert the point clouds. I need a thin layer surface, exactly laid on points. Quote Link to comment Share on other sites More sharing options...
Atom Posted February 21, 2022 Share Posted February 21, 2022 (edited) Give the point cloud iso node a try. Set your step size small for each axis, like 0.05. Edited February 22, 2022 by Atom 2 Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 21, 2022 Share Posted February 21, 2022 You also try the vdb from particle fluid and play with different settings to get the look that you are looking for. PointCloud_To_Surface.hip 1 Quote Link to comment Share on other sites More sharing options...
sebkaine Posted February 21, 2022 Share Posted February 21, 2022 with the command line tool PoissonRecon from my link i get the following result. the utility is pretty straightforward, and can be call directly from houdini like the Labs tools. surfacing.zip 2 Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted February 22, 2022 Share Posted February 22, 2022 Using third party tools: Meshlab 2021.10 Import Mesh the point cloud as OBJ file 1/ Compute Normals for Point sets 2/ Surface Reconstruction: Screened poisson (those are the full names of the functions, you can type them in the upper right magnifying glass search field) I can't elaborate too much on the parameters, but you should be able to reconstruct the surface in some case, especially if the point cloud still looks like a surface, not your use case, as it will output a surface, but something that doesn't really look like the original rubber toy I think it works well for example, to rebuild the mid section of a character if the hole size is in the same ballpark as the average distance between the points; otherwise the rebuilt surface will not bridge the two parts together. Lots of parameters to play with though... Quote Link to comment Share on other sites More sharing options...
davpe Posted February 24, 2022 Share Posted February 24, 2022 shame this functionality doesn't come as a node in Houdini out of the box. it would be really handy sometimes. Quote Link to comment Share on other sites More sharing options...
Yader Posted February 25, 2022 Share Posted February 25, 2022 Here's a free orbolt tool using the aforementioned poisson reconstruction executable: https://www.orbolt.com/asset/organics::organics_sop_poisson_surface_reconstruction_wrapper Quote Link to comment Share on other sites More sharing options...
flcc Posted February 26, 2022 Share Posted February 26, 2022 (edited) These command line and asset are pretty cool. By the way I have two comment these two lines to make the asset work #cmd.append("--color") #cmd.append("16") But without normals (Which is often the case with point clouds), you still have to use mash lab, which reduces the interest of using them. Is there a way to calculate the direction of normals on a point cloud without recoding the algorithm in VEX ? I tried with the @N = @P trick, it's not as bad as I expected, but it's still not great. Edited February 26, 2022 by flcc Quote Link to comment Share on other sites More sharing options...
vinyvince Posted February 28, 2022 Share Posted February 28, 2022 (edited) If you are not happy with the normal from particle fluid (or more usually, this one is too slow) or you would have to use the covariance matrix to get decent normal, that's the only way io know so far working good enough for me https://jakerice.design/2018/09/19/Covariance-and-Principal-Component-Analysis/ Edited February 28, 2022 by vinyvince 1 Quote Link to comment Share on other sites More sharing options...
flcc Posted March 1, 2022 Share Posted March 1, 2022 Yes I tried the differents methods (those of the forum and particles fluid normal) but the jacke rice one is definitively better. Thank. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted March 1, 2022 Share Posted March 1, 2022 For those who have the time to investigate i agree with antoine that meshlab would give the best toolset for the job, and even more. cause it can be use in command line, it work under windows or linux env, and function can be call in python inside houdini. compute_normal_for_point_clouds https://pymeshlab.readthedocs.io/en/latest/filter_list.html?highlight=point normal#compute_normal_for_point_clouds generate_surface_reconstruction_screened_poisson https://pymeshlab.readthedocs.io/en/latest/filter_list.html?highlight=poisson#generate_surface_reconstruction_screened_poisson Quote Link to comment Share on other sites More sharing options...
vinyvince Posted March 1, 2022 Share Posted March 1, 2022 7 hours ago, flcc said: Yes I tried the differents methods (those of the forum and particles fluid normal) but the jacke rice one is definitively better. Thank. You Welcome Quote Link to comment Share on other sites More sharing options...
Masoud Posted March 4, 2022 Author Share Posted March 4, 2022 Thanks to everyone, As @Atom said, the Houdini has an SOP called "Point Cloud ISO" for this purpose. Quote Link to comment Share on other sites More sharing options...
Keshaw singh Posted May 23, 2022 Share Posted May 23, 2022 so helpfull thanks Quote Link to comment Share on other sites More sharing options...
