Hi guys, I want to simulate two (or more) boats in a large ocean, so I tried to use the "Wave Tank" from the shelf, but it creates a following fluid around one of them, and I don't know how should I add the second (or third) one to the sim. Most of the tutorials show how to make it with one boat. I think I should merge the "Particle Fluid Masks" of them..! I would appreciate any ideas. Two Boats_01.hip
- 6 replies
moon94 joined the community
- 6 replies
folvaen joined the community
gimpy0 joined the community
up -
- 6 replies
Chani joined the community
