bookaya619 started following Atom
may be temperature channel act as emissive you can check
VAT Dynamic Remeshing appears corrupted in Unreal 5.2
pandapin223 replied to vamuse's topic in Games
this fx is made of pop or flip in houdini ? cuz dynamic remeshing made from pop dose not work properly in UE.- 1 reply
- unreal engine 5
- vat unreal vertex
Labs VAT > Advance > (Allow Exporting Real-Time Data JSON File (Legacy) ON and Support Real-Time Instancing on) Mkaing this Option ON Houdini Will Export data.json file open That and copy bound min max xyz values to ue material instance. this should work properly with niagara.
guonan100 joined the community
GlennimusPrime started following Pop Advect By Volume Problems
With Pop Advect By Volume inside a POPnet, when particles reach the edge of the volume / the volume bounds, they lose all velocity and just stop. I recall seeing a video somewhere of someone who builds a better Pop Advect By Volume node, by diving inside and setting the particle velocity to continue, rather than just hitting zero. Does anyone know the video I'm talking about? I cannot find it anywhere. Or does anyone have any ideas on how to implement this technique?
adamknauer1 replied to adamknauer1's topic in General Houdini Questions
@Shieh3YES! That's the tutorial. Thank you so much -
Siyun joined the community
Data_Man joined the community
arevcuk joined the community
Nurbek joined the community
pip joined the community
megm joined the community
Thank you That exactly what am was looking for -
Chatbot??
- pipeline
- automation
(and 3 more)
