@Masoud Yes I get it , air field system and Use in Sop solver inside Your Dop to define yours groups water and Density Mass . You have Files here on Forum or Sidefx forum or Peoples post some strange HDA on web, you can Find if I can . I would make so.. it works in Cup too. Here its just some dir and amp on vel-...If you mean Like This ..a lot to tweeek.. IDK
- 7 replies
Hi guys, I want to simulate two (or more) boats in a large ocean, so I tried to use the "Wave Tank" from the shelf, but it creates a following fluid around one of them, and I don't know how should I add the second (or third) one to the sim. Most of the tutorials show how to make it with one boat. I think I should merge the "Particle Fluid Masks" of them..! I would appreciate any ideas. Two Boats_02.hip
- 7 replies
moon94 joined the community
- 7 replies
folvaen joined the community
gimpy0 joined the community
up -
- 7 replies
Chani joined the community
