benjo Posted January 5, 2018 Share Posted January 5, 2018 Hello , here are my wishes for 17.0 ; I would like to have more modelling tools (inspired from my 3ds max experience) -Some preview handle to manipulate bezier curve (i don't know if it's possible with the order parameter) but it will be easier to construct shape with smooth and hard angles and also with bezier surface (i miss the 3ds max patch tool ...i think it's great to produce stylized shapes) -A polysplit edge loop or insert loop that respect curvature (like in 3ds max) -and also a make circle that respect curvature 1 Quote Link to comment Share on other sites More sharing options...
kev2 Posted January 7, 2018 Share Posted January 7, 2018 Two buttons on each help page: Typo and Inaccurate, similar to the ❤️ button. You click the button and can highlight the text that is a typo or incorrect. Click the button again and the page submits it to the Docs team, effectively making all of us proofreaders. You could go all out and have a little comment box pop up too. Being too lazy to file a bug report unless things are crashing, I never do for typos or inaccuracies in the docs, which aren’t often in Houdini’s docs, but sometimes things change over versions and a line or two of a doc is made inaccurate, but would if it were just a click or two. 3 Quote Link to comment Share on other sites More sharing options...
pxBomber Posted January 8, 2018 Share Posted January 8, 2018 Support for "real" tabulator char. in wranglers. Automatically fill Label parameter from parameter Name (can involve some smart conversion like "my_foo" -> "My Foo"). 1 Quote Link to comment Share on other sites More sharing options...
Sepu Posted January 13, 2018 Share Posted January 13, 2018 I'm sure this has been said many times on this thread for 15 , 15.5, 16, 16.5 and now 17 But The Cloth/FEM Solver needs to be UPDATED please, thank you! Is awfully slow. 3 3 Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 7, 2018 Share Posted February 7, 2018 In the Network Editor ... please give us option to "Don't edit name of the node by simple LMB onto its label". Does it happen to you too? Accidentally editing the name? To me, too often I would like to start LMB click/drag even on the label. 3 Quote Link to comment Share on other sites More sharing options...
Atom Posted February 7, 2018 Share Posted February 7, 2018 Untying tangents in the graph editor should be much simpler. It should work like After Effects. Simply ALT-CLICK on an existing tangent handle to untie it. 3 Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 7, 2018 Author Share Posted February 7, 2018 On 2/7/2018 at 1:30 PM, ikoon said: In the Network Editor ... please give us option to "Don't edit name of the node by simple LMB onto its label". Does it happen to you too? Accidentally editing the name? To me, too often I would like to start LMB click/drag even on the label. Expand I actually like this idea a lot... certainly not as a default when your building out new scenes and such and constantly editing. But certainly when dealing with near final complex scenes or doing cleanup work I run into this often. Quote Link to comment Share on other sites More sharing options...
pxBomber Posted February 7, 2018 Share Posted February 7, 2018 On 2/7/2018 at 3:39 PM, LaidlawFX said: I actually like this idea a lot... certainly not as a default when your building out new scenes and such and constantly editing. But certainly when dealing with near final complex scenes or doing cleanup work I run into this often. Expand I think it's a part of the more generic problem of H. UI. In many cases houdini reacting to "mouse-button-down" / "key-press" immediately unlike most of other software's where command is executed after complete event (key down ... key up). It's sometimes a problem in the viewport as well. Quote Link to comment Share on other sites More sharing options...
bonassus Posted February 13, 2018 Share Posted February 13, 2018 A better illustrator importer would be nice. Specifically one that can imports open curves. The way C4D does. This would be an advantage to those considering Houdini for motion graphics. 2 Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 19, 2018 Share Posted February 19, 2018 As in the picture: If the cursor hovers over a pane, which is alone, so there is nowhere to Ctrl-Tab... then the Ctrl-Tab hotkey will swap between parm interface folders. OR Another simpler detection of „hover over folders" + ctrl+tab --------> swap parm folders. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 24, 2018 Share Posted February 24, 2018 if I heard it correctly at the Sydney Sidefx presentation H17 will be released around Sept, also there is some nice work done on the muscles that might be available in some months. Had to leave early so probably missed a ton of stuff too. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted February 25, 2018 Share Posted February 25, 2018 I look forward to 17 since I'm still using 15.x; I hope for the best. Quote Link to comment Share on other sites More sharing options...
nisachar Posted February 26, 2018 Share Posted February 26, 2018 On 2/24/2018 at 5:59 AM, marty said: if I heard it correctly at the Sydney Sidefx presentation H17 will be released around Sept, also there is some nice work done on the muscles that might be available in some months. Had to leave early so probably missed a ton of stuff too. Expand Say what ? I was under the impression it was 'in a couple of months time' or 'two months time' for Houdini 17. I didn't hear anything about a September 2018 launch date. Quote Link to comment Share on other sites More sharing options...
Njordy Posted February 26, 2018 Share Posted February 26, 2018 On 2/26/2018 at 11:48 AM, nisachar said: Say what ? I was under the impression it was 'in a couple of months time' or 'two months time' for Houdini 17. I didn't hear anything about a September 2018 launch date. Expand Well, I believe they gonna announce and showcase H17 in a month or two, but it's gonna take months between the presentation and public release. So, July-Septemer Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 26, 2018 Author Share Posted February 26, 2018 Around Siggraph is their historical average for a summer releases. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted March 7, 2018 Share Posted March 7, 2018 (edited) Having a VEX command to query u coord of a point on a curve directly would be great. f@u = ucoord(0,@P); The best option in vex is still : // Run Over -> Points int prim; vector uv; xyzdist(0, @P, prim, uv); int mode = 4; // PRIMUV_UNIT_TO_UNITLEN u@uv_profile = primuvconvert(@OpInput1, set(uv.x, 0.0), prim, mode) vex_command_u_coord.hiplc Edited March 7, 2018 by sebkaine Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted March 7, 2018 Share Posted March 7, 2018 On 3/7/2018 at 12:34 PM, sebkaine said: Having a VEX command to query u coord of a point on a curve directly would be great. f@u = ucoord(0,@P); The best option in vex is still : // Run Over -> Points int prim; vector uv; xyzdist(0, @P, prim, uv); int mode = 4; // PRIMUV_UNIT_TO_UNITLEN u@uv_profile = primuvconvert(@OpInput1, set(uv.x, 0.0), prim, mode) vex_command_u_coord.hiplcFetching info... Expand I usually just put a resample node before my wrangle and let it create curveu... Although this works best when actually resampling. Quote Link to comment Share on other sites More sharing options...
sebkaine Posted March 7, 2018 Share Posted March 7, 2018 Thanks thomas , the pb with resample is that it create uniform space beetween points, i you want to get uv coord it's not working. In the hip attach the first method use a resample to get u with att transfer. Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted March 7, 2018 Share Posted March 7, 2018 I see. I guess I work too much with organic shapes where this is actually what I want... :-) Cheers and sorry for the noise, Tom Quote Link to comment Share on other sites More sharing options...
The xon Posted March 7, 2018 Share Posted March 7, 2018 On 2/6/2017 at 11:13 PM, LaidlawFX said: Houdini 16 launch has been announced, February 21st! A unified node context, I know this drives people banana's, but it should be a choice to work in different node contexts. Not a mandatory obligation that you need to be in /obj/ Scene, /obj/sop/ Sops, Dops, Materials, etc. to perform those task. Houdini was created with the combinations of several different programs as defined by these contexts nearly 20 years ago now. It's time to UNITE them all! We can still keep the old Context's just as POPs still lives under the hood, or you can just unleash the / context to us all, but it would be nice to work in a unified context i.e. Nuke. And as always it's the users responsibility to keep their network clean! Thank SideFX gods for the wire dots, and the circular contexts. Expand I agree with everything except this, a unified node context is a very bad idea. the number of sops(vops or even dops)is very intimidating as is,having them all in one place would just be too clustered, i imagine wanting certain sop,and having a million nodes to scroll through,... plus if i want a file dop,how do i specify i want a file dop and not a file sop or a file chop?.....nuh let the different context stay different Quote Link to comment Share on other sites More sharing options...
