Hi, I use a rop alembic node to save a tree of obj/geo nodes. For pipeline purposes, the nodes in the alembic file must have special characters like ':' (e.g. transforms should be like objA:X), however in houdini a node name cannot have ':' (i.e. houdini will change the name from objA:X to objA:X). Is there any workaround? cheers
How to create nested obj level transforms?
catchyid replied to catchyid's topic in General Houdini Questions
okay, I guess my post is not clear I will describe the problem and the solution I found, hope it's clear ! In houdini, can we have nested object nodes (so a transform that includes a transform and so on? final result the inner geometrical shape will have final transformation for all parent transform), answer is yes, it's possible to create an "obj" subnetwork, that constains another "obj" subnetwork , and so on... Cheers -
@Masoud Yes I get it , air field system and Use in Sop solver inside Your Dop to define yours groups water and Density Mass . You have Files here on Forum or Sidefx forum or Peoples post some strange HDA on web, you can Find if I can . I would make so.. it works in Cup too. Here its just some dir and amp on vel-...If you mean Like This ..a lot to tweeek.. IDK
- 7 replies
Hi guys, I want to simulate two (or more) boats in a large ocean, so I tried to use the "Wave Tank" from the shelf, but it creates a following fluid around one of them, and I don't know how should I add the second (or third) one to the sim. Most of the tutorials show how to make it with one boat. I think I should merge the "Particle Fluid Masks" of them..! I would appreciate any ideas. Two Boats_02.hip
- 7 replies
moon94 joined the community
- 7 replies
folvaen joined the community
gimpy0 joined the community
up -
- 7 replies
Chani joined the community
thanks will check this asap =)
