  1. Yesterday
  2. Hi, I use a rop alembic node to save a tree of obj/geo nodes. For pipeline purposes, the nodes in the alembic file must have special characters like ':' (e.g. transforms should be like objA:X), however in houdini a node name cannot have ':' (i.e. houdini will change the name from objA:X to objA:X). Is there any workaround? cheers
  3. like this ??? But this is not a stable model and can easily lead to problems
  4. okay, I guess my post is not clear I will describe the problem and the solution I found, hope it's clear ! In houdini, can we have nested object nodes (so a transform that includes a transform and so on? final result the inner geometrical shape will have final transformation for all parent transform), answer is yes, it's possible to create an "obj" subnetwork, that constains another "obj" subnetwork , and so on... Cheers
  5. @Masoud Yes I get it , air field system and Use in Sop solver inside Your Dop to define yours groups water and Density Mass . You have Files here on Forum or Sidefx forum or Peoples post some strange HDA on web, you can Find if I can . I would make so.. it works in Cup too. Here its just some dir and amp on vel-...If you mean Like This ..a lot to tweeek.. IDK
  6. Hi guys, I want to simulate two (or more) boats in a large ocean, so I tried to use the "Wave Tank" from the shelf, but it creates a following fluid around one of them, and I don't know how should I add the second (or third) one to the sim. Most of the tutorials show how to make it with one boat. I think I should merge the "Particle Fluid Masks" of them..! I would appreciate any ideas. Two Boats_02.hip
  7. For say, I need to apply some effects, only to the water's surface, in a cup. So I don't need that effect, where the fluid contacts the container, thus I need an attribute that shows particles on the top of the fluid surface.
  8. @Masoud You want something Like Mask to control That filed or?
  9. Last week
  10. Hello, I have been trying to solve this issue for days and can't figure it out. I have a groom sim done with the object-level groom tools. Inside a GuideGroom Object, I am deforming a highres groom with the simulated lowres groom, with the guide deform Then I feed this output into a hairgenerate and this is where the issue appears. Id attribute is jumping and some hair jump positions, but this is not happening after the guide deform upstream Any ideas what could have gone wrong? Best
  11. Hi! I want to mimic Maya transforms structure in Houdini, i.e. transform node A, when you dive, you will find another transform node B, when you dive in you find transform C. Just to clarify, I understand I can flatten this hierarchy by connecting obj level transforms in parent-child relationship (so all nodes will be on top level obj), but I don't want this. The only way I am to do is by creating obj sub-networks, for example: root obj --contains--> object sub-network A --dive in--> obj sub-network B. Is there any other solution? Tx
  12. @GenesisCry this its not solution but can you try that with Pop Grains . BubblesBB.hipnc
  13. Hi Paranoidx, That's the problem: how can I exclude the "bound container"?
  14. Oh excellent! Thanks. I'll be diving into this asap.
  15. @RT_SD I found this file with diff methods, can be useful just to Post here. vellumPressure_methods.hipnc
  16. Hey Tesan, thanks for the reply. If you scroll down a bit do the mask values stop after prim number 15? Presumably so as you have an array of 16 objects. I think I've confused myself by only doing 1 cushion. So the pressure constraint IS just a single prim so you can't actually vary the pressure values across the object on that, its all or nothing? The varying is done on the stretch and bend cloth constraints... which PE demos in his video if I paid proper attention! In my defence it is a bit counter intuitive in that to vary the inflation effect you have to do it with the cloth properties not the pressure. At least hat's how Mr Esteves has done it here. When I checked the Docs though they have that flippy inflation scene which uses a built-in @pressurescale point atttribue. Presumably that is stored on each point of the pressure prim and *does* allow you to inflate diferentially across an object using pressure, or does it??? (that flippy scene was a bit complicated as it also has a volume variable doing something as well, I will revisit it now I've cleared up my wrong thinking)
  17. @RT_SD I have this on my Spreadsheet<<<< Totally different from yours
  18. I've created a HIP that reproduces the problem in a more manageable way UPRES.hip
  19. https://ibb.co/Y2N8z8B Made a grid to use its points as your particle sources connected a pop net to it In the pop net i mainly edited the POP Source Source Tab: changed geometry source to "use first Context Geometry" to use grid points as sources Birth Tab: Crank your "Const Birth Rate" a little up and change the "Jitter Birth Time" to negative. This made the points fall a little more unperfect Attributes Tab: "Initial Velocity" gets setted to Set innitial v and than adjust the variance slightly of x and z. The points will not fall straight downward but a little left and right. i added an additonal nodes like "popinteract" to get them a bit together if they are close or add some forces to mak their movement a little more random like a small "pop wind" or so Outside the Popnet i added some additional nodes so the points get geometry. added a "attributeadjustfloat" with a operation as "set initial" and Pattern Type as "Random" with Min/Max values to my likeing (this randomly changed the size of the "droplets") added a "vdb from particles" node with quiet a small point radius and smaller voxel size. added a convert vdb and set it to polygon to get the final geometry. https://ibb.co/TPxDzsr
  20. I watched Paul Esteves' Hive froma few days ago, and followed his example for inflating a cushion using pressure constraints. I wanted to understand how to control pressure with animated antributes. I can't get his VEX code to work, and I can't understand why it doesn't, but worse I don't understand why it would if it did! (It doesn't vary the pressure across the geometry). He's setting a mask attrib on the main geo, then referencing this on input 3 of a Geometry Wrangle in the solver set to the ConstraintGeometry stream. Here's the code, with my atribute inserts for saving out the varibales so I can try to see what's happening in the spreadsheet. int pt = primpoint(0, @primnum, 0); i@mpt = pt; float falloff = point(2, "mops_falloff", pt); f@mask = falloff; falloff = fit01(falloff, chf("min"), chf("max")); f@restlength = f@restlengthorig * falloff; The code is using primpoint() to get the point number of the first vertex of each constraint prim, storing it in pt and multiplying this with the mops_falloff mask and saving it to @restlength of the pstretch group (named in the Pressure constraint SOP). But when I inspect @mpt ('mpt' so it's next to 'mask' in the spreadsheet), its all zeros. 'That would explain why it's not working' I think... iiuc though, the pressure contraint is just a single polyline, 1 prim, connecting many points stored in an array (@pts) and so has just one restlength attribute. So I don't see how this code could write the differnt masked values as there's only a single entry for it. I must be misunderstandning something but cannot figure out what. See grab. Here's the part of the vid with the code in a Geometry Wrangle in the Vellum Solver:
  21. A noob grains upres question here… I created a massive fracturing grains sim with Vellum at a low-ish resolution, and I'm using the grains' velocities to drive smaller dumber particles. When using the POP Advect by Volume, the particles are pushed around correctly as expected, but when they exist the Velocity field they slow down dramatically almost to a halt. This is because I am using "Treat as Wind" with very high "Air Resistance" values, to counteract the Gravity force. How can I sample the Density of the same volume, and use that to influence the "Air Resistance"? This way the core of the volume will stick to the Velocity, and as we get further away from the core, the Velocity will have less and less influence, with gravity taking over... I spent hours on this yesterday, trying to find a way to bring the volume Density into the DOPNet as a sort of falloff for the POP Advect by Volume node… I even tried transferring the volume density to the Grain source points in SOPs as a float value, hoping I could hook strength data out of them that way, but again, just not luck at all! I’m aware this must be incredibly simple to do, but I just cannot figure it out at all. There doesn’t seem to be any kind of masking options available in the nodes I’m using. One kind Facebook user on the Houdini Artists group told me this VEXpression could be pasted into the POP Advect by Volume node: @airresistance *= fit(length(volumevelocity), 0, value, 0, 1); value = the speed value where you want the resistance to be full. However, this is not referencing density, and so far, isn't working anyway - but I get the idea.... Can anyone advise on the best steps to do this?
  22. Here is one way to do it you can play inside the pop solver how much the particles live, etc fx_particle.hip
  23. This is what would be final goal, but this was done in C4D
