  2. Modelling Zen Stone Garden
    @hmihalis1if you wind your self lost play with this ..... srle01.hipnc
  3. Modelling Zen Stone Garden
  4. Modelling Zen Stone Garden
  5. Modelling Zen Stone Garden
  6. Modelling Zen Stone Garden
  7. Modelling Zen Stone Garden
  8. Today
  9. Modelling Zen Stone Garden
  10. Laptop for houdini
  11. In/Active Constraints
  12. Hi Guys, The scene is suppose to a transition bettween clear sky to cloudy wheater. I made an single cloud look using sphere feeding an cloud SOP then i animated the density field inside the sky SOP, after i convert the sky SOP to an polygon VDB. However when i try to use the polygon VDB to feed the cloud SOP, it wont work. (i figured out that was something when convert sky SOP to polygons, but not sure at all) my second attempt was export an sequence vdb, with no luck again. Any light on the tunnel???? anim_cloud_v00.hip
  13. Exploding Fruit!
  14. Hair inherit groups from skin
  15. Yesterday
  17. RBD Collision Problem
  18. egg explosion
  19. Add color to existing color based on attribute?
  20. "Mud worms".Heightfields+SOP solver
  21. Permission Denied?
  22. Vellum export alembic
  23. egg explosion
  24. Vellum export alembic
  25. In fact, I have yet to find a operator definition type that has the 'New Output' option unlocked??
  26. Nature fun
  27. Pyro renders taking way too long
  28. Hi! I create these mountains on my shape with a noise by getting that noise by affecting the @P.y attribute. Of course the mountains are thinner when my shape goes more steep, because the points distributed through the Z axis are more dense there. To resolve this I thought I should use a different Pos for the noise, so I created a grid and put it in the second input. But when I use getattrib(P) on that input and plug it into the noise, I don't get the expected results. (It seems to do nothing much) Is it that you can't use differents Noise pos' like this? Does the topology have to match with the geometry or something? How does this work, exactly? How would one go about evenly distributing the noise position along the Z-Axis? So that you have just as thick mountains everywhere, no matter how steep? Hope you can help me. Thanks.
