  2. Modelling Zen Stone Garden
    @konstantin magnus thanxxx
  4. Modelling Zen Stone Garden
    Welcome Harry, you could put a sine wave on the distance from each particle to the closest position on the rocks. zen.hipnc
  5. I found out that: "vdb"node follow by "vdb activate" will create exactly the vel attribute as one. Doesn't need to use the vector merge.
  6. Modelling Zen Stone Garden
  7. Modelling Zen Stone Garden
  8. Modelling Zen Stone Garden
  9. Modelling Zen Stone Garden
  10. Modelling Zen Stone Garden
  11. Modelling Zen Stone Garden
  12. Modelling Zen Stone Garden
  13. Laptop for houdini
  14. In/Active Constraints
  15. Hi Guys, The scene is suppose to a transition bettween clear sky to cloudy wheater. I made an single cloud look using sphere feeding an cloud SOP then i animated the density field inside the sky SOP, after i convert the sky SOP to an polygon VDB. However when i try to use the polygon VDB to feed the cloud SOP, it wont work. (i figured out that was something when convert sky SOP to polygons, but not sure at all) my second attempt was export an sequence vdb, with no luck again. Any light on the tunnel???? anim_cloud_v00.hip
  16. Exploding Fruit!
  17. Hair inherit groups from skin
  18. Yesterday
  19. Hair inherit groups from skin
  20. RBD Collision Problem
  21. egg explosion
  22. Add color to existing color based on attribute?
  23. "Mud worms".Heightfields+SOP solver
  24. Permission Denied?
  25. Vellum export alembic
  26. egg explosion
  27. Vellum export alembic
  28. In fact, I have yet to find a operator definition type that has the 'New Output' option unlocked??
