  2. Vex help
  3. Vex help
  5. Vex help
  6. Stretch UI
  7. Hi there, First time posting here . I am working on my final bullet destruction project for school and I was wondering if there was a way to constrain window glass, for example, to already cached pieces. I am trying to do layered destruction, where I first do the concrete layer then read those into a glass simulation where the glass is constrained to and collides with the concrete cache, and so on. I was told it was possible to do this as follows: "You can unpack pieces of your original sim near your windows and then use a Point Deform SOP to bind your packed window pieces to them! As usual, set them to i@active = 0 and i@animated = 1 until you're ready to have their own secondary simulation take them over. You can add all of your preliminary simulation in as a collider too in the same manner" The problem is I am not that familiar with the Point Deform SOP and don't know where to start with it. I have Googled around and haven't found much regarding this topic. I had previous experience with Thinking Particles and this method using cached layers was common. Thanks in advance for any insights. I have attached my hip file in case you want to take a look. Thanks D layered_destruction.hiplc
  8. Yesterday
  9. Od Studios launch
  10. Abstract in Houdini - Course
    Glad you liked it!:D
  11. Stretch UI
  12. Euler to orient-matrix inside dops.
    its done
  13. Run script in Command Line tools with Python
  14. Abstract in Houdini - Course
  15. meshing fractals
  16. There's ways to decompose/describe a vector - 3 coordinates (xyz) that scale the coordinate system unit vectors (ijk) and add them together: P = i*x + j*y + k*z. - direction (vector scaled to length 1) and legth magnitude (distance from tail to head of the vector) - direction (two angles) and length So you use the representation that is more sensible to the operation you are doing. For angular related calcs direction is handy, while for position calcs you want to deal with xyz, etc.
  17. If a vector also has a length, why is it perceived to be of 3 values?
  18. If a vector also has a length, why is it perceived to be of 3 values?
  19. Nature fun
  20. length = square root of (x^2 + y^2 + z^2) direction = normalize (x,y,z) [puts that point on the surface of a unit sphere] https://www.3dgep.com/3d-math-primer-for-game-programmers-vector-operations/ You should check out dot and cross product too: https://betterexplained.com/articles/cross-product/
  21. hi, I am testing vellum, and have a question. When testGeo is coming up from ground, all vellum particles are influenced and pushed away. Also, when he hit ground with hummer and lift it up, particles looks being sucked into holes made by hummer. However, these particle reaction should not reach such far away distance. I'd like to know how to control the influence distance. So far, I am thinking of solutions: 1 - reduce constraint iteration, 2 - make a space between particles at emission/creation times. 3 - add more friction, increase particle separate / highres- sim, etc. This result could be ok for sand FX, but when making snow ground, this won't work. Particles should be very rigid, and particle only moves around testGeo's feet and hummer. If anyone knows how to control it properly, let me know thanks!!
  22. SOP_PointWave example questions ....
  23. Abstract in Houdini - Course
  24. Align Geometry on Spline along TangentU and Y-Axis
  25. Houdini 18 Wishlist
  26. Stretch UI
  27. "standard" pyro and deforming mesh
  28. Hi, is there a way to set the "Invisible" toggle on a parm in Parameter Interface with python? All I could find was .hide() function which indeed hides the parameter but if the parameter is horizontally joined with a string parm, it leaves an empty space instead of having the string parm completely fill out the row. It acts the same way as the "Hide When" conditional. So I want to be able to do the same thing as when I open parameter interface and toggle "Invisible" - in python. Thanks
