Karan77 joined the community
nniicckk joined the community
Chatbot??
- pipeline
- automation
(and 3 more)
Kokles joined the community
Bubbly4334 joined the community
Duppep joined the community
THVRQ joined the community
Max1586 joined the community
Shraunqhf joined the community
lopinputprims('.', 0) -
Look into Voronoi Fracture - Earlier
Attribute Growth [SOLVED]
The issue likely stems from how the proxy is exported — it’s being treated as a single mesh without preserving per-component hierarchy. To fix this: In SOPs, ensure each component has a unique path or name attribute (use Name SOP or Attribute Create). In the Redshift Proxy Output SOP, disable "Export as Packed Primitives" to avoid flattening the geometry. In Solaris, when using the Redshift Proxy LOP, set it to "Load as Reference" and confirm that hierarchy is preserved in the Scene Graph Tree. Each component should appear as a separate prim. Once you have separate prims, use Material Library LOP and Material Assign LOP to assign materials to individual components. If the proxy continues to load as a single mesh, consider exporting as USD with proper hierarchy and assigning Redshift materials directly in Solaris for more flexibility. Hope this helps! forward proxy
