@Thoi I see what mean and asking , that was only One thing that I learn how to pull Old Stuff From users on GitHub , in Time those Files that someone Share become somehow invisible over period( or user mark those like somthing) of Time and with "Git program for windows" you can if Possible take those files ..seen some users asking on Github for Sharing those particular files @vinyvince . I need only files to Build Library
- 187 replies
- sacredgeometry
- guilloche
- (and 4 more)
@caskalDid you ever figure this effect out? I'm super curious how you got the effect you were getting in your attempts.
- 6 replies
- heightfield
- painting
Emit 1 Particle Per Sec - Starting From Frame 1
Thanks @Atom! Making great progress! I've also created a 'firing' toggle with your previous vex wrapped in another if statement (if firing == 1, shoot bullets, else remove all points). int fire = chi("firing"); if(fire==1){ if(@Frame!=1){ if ($FF % chf("shoot_every_frames")){ removepoint(0,@ptnum); } } } else{ removepoint(0,@ptnum); } I think I now need to know which frame that fire toggle has been activated? My thoughts are to replace: '@Frame!=1` With: '@Frame!=@fire_activation_frame' I just need to work out how to store that '@fire_activation_frame' attribute when the fire toggle is first set to 1. Any ideas? emit_particles_v03.hipnc
