  2. Run script in Command Line tools with Python
  3. Abstract in Houdini - Course
  4. meshing fractals
    i using classic Julia Fractal to drive my spline :
  6. There's ways to decompose/describe a vector - 3 coordinates (xyz) that scale the coordinate system unit vectors (ijk) and add them together: P = i*x + j*y + k*z. - direction (vector scaled to length 1) and legth magnitude (distance from tail to head of the vector) - direction (two angles) and length So you use the representation that is more sensible to the operation you are doing. For angular related calcs direction is handy, while for position calcs you want to deal with xyz, etc.
  7. If a vector also has a length, why is it perceived to be of 3 values?
  8. If a vector also has a length, why is it perceived to be of 3 values?
  9. Nature fun
  10. length = square root of (x^2 + y^2 + z^2) direction = normalize (x,y,z) [puts that point on the surface of a unit sphere] https://www.3dgep.com/3d-math-primer-for-game-programmers-vector-operations/ You should check out dot and cross product too: https://betterexplained.com/articles/cross-product/
  11. hi, I am testing vellum, and have a question. When testGeo is coming up from ground, all vellum particles are influenced and pushed away. Also, when he hit ground with hummer and lift it up, particles looks being sucked into holes made by hummer. However, these particle reaction should not reach such far away distance. I'd like to know how to control the influence distance. So far, I am thinking of solutions: 1 - reduce constraint iteration, 2 - make a space between particles at emission/creation times. 3 - add more friction, increase particle separate / highres- sim, etc. This result could be ok for sand FX, but when making snow ground, this won't work. Particles should be very rigid, and particle only moves around testGeo's feet and hummer. If anyone knows how to control it properly, let me know thanks!!
  12. SOP_PointWave example questions ....
  13. Abstract in Houdini - Course
  14. Align Geometry on Spline along TangentU and Y-Axis
  15. Houdini 18 Wishlist
  16. Stretch UI
  17. "standard" pyro and deforming mesh
  18. Hi, is there a way to set the "Invisible" toggle on a parm in Parameter Interface with python? All I could find was .hide() function which indeed hides the parameter but if the parameter is horizontally joined with a string parm, it leaves an empty space instead of having the string parm completely fill out the row. It acts the same way as the "Hide When" conditional. So I want to be able to do the same thing as when I open parameter interface and toggle "Invisible" - in python. Thanks
  19. "standard" pyro and deforming mesh
  20. I'm with Houdini 17.5 and when I import a usd/usda file, I can go through the menu , and select the usd/usda file I would like to open in the Choose Geometry dialog. My question is how can I import through a Python script, to do the same thing and not to bother the UI operations? The original post and updates are here: https://www.sidefx.com/forum/topic/65721/?page=1#post-281454 and put it here too to try to get more help. Any help is welcome!
  21. Because the three values defines an imaginary line going from 0,0,0 to the position in space described by the 3 values. That point can be far away or i can be close to 0,0,0. This way the 3 values are able to defines both a direction and a length. -b
  22. Hello, guys! Recently, I'm trying to do a project that needs to connect houdini with arduino. I want to use the data I got from ultrasonic sensor from arduino to change the height of a tube in houdini. But it seems that there are some problems of the connection, Anyone can give me some advice? This is the error message that I got from the software: Error: Unable to evaluate expression ( Traceback (most recent call last): File "<stdin>", line 2, in expression File "opdef:/Object/gwPlatform?PythonModule", line 15, in getHeight File "opdef:/Object/gwPlatform?PythonModule", line 3, in updateValues AttributeError: 'module' object has no attribute 'updateFrame' (/obj/gwPlatform1/tube1/tube1/height)) And here are some screenshots of my project.
  23. Was wondering this when I learned about length vector functions in a tutorial..
  24. Add smaller fracture shards to an Fracture object
  25. 17 export alembic with material?
  26. Greetings! I have 5 branches that have their own unshared edge group. The group is called "widen". I put these into a for each to be able to modify the group for each individual piece with a soft transform. So first I use the $GCX, $GCY, $GCZ in my soft transform and that works, but only for the first iteration of my for each and for the other iteratons the pivot doesn't change from the first iteration. How do I get the pivot to the center of all groups in a for each?
  27. 17 export alembic with material?
